Elastic Collision of two objects
In an elastic collision problem, a 5.5 kg object moving at 5.5 m/s collides with a 2.5 kg object moving at -4.0 m/s. The conservation of momentum and kinetic energy equations are applied to find the final velocities of both masses. The initial calculations led to a quadratic equation, but the solutions obtained (5.51 and -0.448) were incorrect. A suggestion was made to double-check the quadratic solution, indicating that the previous work was mostly correct but contained an error in the final calculations. Correctly solving the quadratic will yield the accurate final velocities for both objects.
Bowenj
A 5.5 kg object moving in the +x direction at 5.5 m/s collides head-on with a 2.5 kg object moving in the -x direction at 4.0 m/s. Find the final velocity of each mass for each of the following situations. (Take the positive direction to be +x.) The equation is elastic
m1v1+m2v2=m1v1'+m2v2'
.5m1(v1)2+.5m1(v1)2= 5m1(v1')2+5m2(v2)2
I plugged the numbers into the first equation, and solved for v2', which gave me 8.1-2.2v1'=v2'
Then i substitued this into the second equation, which gave me
103.1875=.5(5.5)(v1')^2+(.5)(2.5)(8.1-2.2(v1'))^2
then i simplified and go
103.1875 = 2.75(v1')^2+1.25(65.61-35.64v1'+4.84(v1')^2)
I simplified again and got
0= 8.8(v1')^2-44.55v1'-21.175
Okay so then i used the quadratic equation and got 5.51 and -.448, but neither one of those answers are right.
Double check your solution for that quadratic. Your answers are off a bit. (And solving that quadratic correctly does give the correct answer, so your work up to that point is good.)
