Elastic relativistic collisions
In a perfectly elastic relativistic collision, rest mass is not conserved, while momentum, energy, and angular momentum are conserved. Non-relativistic concepts of conservation do not fully apply to relativistic collisions, leading to confusion about which quantities remain constant. Experiments validate that relativistic momentum is conserved even in inelastic collisions, and rest mass is defined to be conserved in such scenarios. Energy conservation is confirmed through the relationship involving momentum and mass. Overall, both momentum and angular momentum conservation hold true in relativistic collisions when analyzed correctly.
Amith2006
# In a perfectly elastic relativistic collision, which one of the following quantities is not conserved:
a)Momentum
b)Energy
c)Rest mass
d)Angular momentum
In non relativistic elastic collisions, energy and momentum will be conserved. But I don’t know about relativistic elastic collisions. Could anyone please clear my doubt? Can we apply the Newtonian concepts in these cases? Suppose the collision is inelastic (relativistic), then which quantity will be conserved?
I'm puzzled. As far as I know, there is no way to prove conservation of momentum. However, experiments confirm that relativistic momentum is conserved in inelastic collisions (such as particle collisions). Rest mass is conserved by definition of an inelastic collision. Energy is \sqrt{p^2c^2+m^2c^4} so it is conserved since p and m are. Regarding the angular momentum, if you take the coordinate system in which the collision is monitored to have its origin at the point of collision, then angular momentum before and after the collision are 0. So, angular momentum is conserved too.
