Electric Charge and Magnetism: Constant or Varying Magnetic Field?
A moving electric charge creates a magnetic field that is constant if it maintains a constant velocity, according to the Biot-Savart law. However, if the charge accelerates, it generates a time-varying magnetic field, which can lead to electromagnetic radiation. The discussion clarifies that while the fields change as the charge moves, they remain localized to the charge and do not produce radiation at constant velocity. The Lienard-Wiechert potentials describe the fields from a moving charge, highlighting that the relationship to the charge remains consistent despite changes in position. Understanding these principles is essential for grasping the dynamics of electric charge and magnetism.
Dikshant
If an electric charge is moving with constant velocity,what does it create?? A constant magnetic field or 1 which is varying with time?? What if it accelerate?
Does a wire with a constant current through it create a magnetic field?
Thanks for reply,but m already a bit confused and that's a different case.
Yeah,a constant magnetic field
ChrisVer said:
yes it generates a constant in time magnetic field following the Biot Servart law
http://maxwell.ucdavis.edu/~electro/magnetic_field/pointcharge.html
If it is accelerated it is going to generate radiation (time varying magnetic field)
And
And what happens when a varying electric field is working in an area??
If it is accelerated it is going to generate radiation (time varying magnetic field)[/QAnd
The fields from a moving charge are given by the Lienard Wiechert potentials
http://en.wikipedia.org/wiki/Liénar...onding_values_of_electric_and_magnetic_fields
It doesn't have an explicit time dependence, but the input variables are functions of time so the result is also.
Yes you are right DaleSpam...
Indeed, I misinterpreted this...I also thought about that when I saw the r in the equation, but then... I got confused with the u=const case not generating electromagnetic radiation... but the EM radiation is something different (has to do with the Poynting vector as well)...
Yes that is correct. The fields generated by the Biot Savart law or the Lienard Wiechert potential for constant velocity do not generate "radiation". The fields stay localized to the charge. They change over time, as the charge moves, but their relationship to the charge doesn't change.
Thank you all
