Electric Charge Equilibrium Calculation
9 replies · 4K views · last reply
Goldenwind
[SOLVED] Electric Charge
Two point charges q and 4 q are distance L apart and free to move. A third charge is placed so that the entire three-charge system is in static equilibrium. What is the magnitude of the third charge?
F = kq1q2 / r^2
k ~= 8.988x10^9
Not a clue. All I've figured out is that for this to work in perfect equilibrium, the third charge must be directly in between the first two.
Not looking for an all-out solution from anyone (Although that'd be cool too), but more looking for just a push in the right direction.
In theory, it'd involve drawing free body diagrams for the three charges, and then working with the charge q3 to balance the equilibrium... but I can't grasp my head around that.
yes! just need to go ahread and write down some simultaneous equations and solve them... obviously the variables will be the charge for the unknown/3rd particle, and its distances from each one.
Particle 3:
Net Force = 0 = F1 + F2
-F1 = F2
-kq1q3/(r13)^2 = kq2q3/(r23)^2
The problem here is that I don't know the distance between 1 and 3, or between 2 and 3.
Also, the q3 cancels out on each side. /boggle
also need equations for particle 1 and 2, all particles must have net force add to zero, since particle 3 is in between the two, the the two distances (13, 23) should add to L which gives u another equation... I haven't solved this, but that's how you go about it.
Particle 1:
Net Force = 0 = F2 + F3
-F2 = F3
-kq1q2 / L^2 = kq1q3 / (r13)^2
-4q / L^2 = q3 / (r13)^2
Particle 2:
Net Force = 0 = F1 + F3
-F3 = F1 (Doing it the other way, since the force would be in the other direction)
-kq2q3 / (r23)^2 = kq1q2 / L^2
-q3 / (r23)^2 = q / L^2
L = r13 + r23
r13 = L - r23
-4q / L^2 = q3 / (L - r23)^2
Unsure where to go from here. Could simplify the above line a little, but then I'd still have two unknowns: q3 and r23.
Wait, I have an idea..
-Sqrt((q3*L^2) / -4q) + L = r23
Which means:
r13 = L - r23
r13 = Sqrt((q3*L^2) / -4q)
Then from the particle 3 formula... plugging in r13 and r23...
-q3/(r13)^2 = 4q3/(r23)^2
-q3/(Sqrt((q3*L^2) / -4q))^2 = 4q3/(-Sqrt((q3*L^2) / -4q) + L)^2
-1/(Sqrt((q3*L^2) / -4q))^2 = 4/(-Sqrt((q3*L^2) / -4q) + L)^2
-((q3*L^2) / -4q) = ((-Sqrt((q3*L^2) / -4q) + L)^2) / 4
q3*L^2/q = ((-Sqrt((q3*L^2) / -4q) + L)^2)
Just checking, am I on the right path? Computing the right side is going to be a HUGE mess, I don't want to do it if I'm already doing things wrong.
I haven't checked the last bit but once you have got those equations it is just a matter of solving them... and method of substition seems to be the way to go.. so you are on right track
Sigh... here goes nothing.
q3*L^2/q = (-Sqrt((q3*L^2) / -4q) + L)^2
q3*L^2/q = 2L^2 - q3*L^2/4q3
q3*L^2/q = 2L^2 - L^2/4
q3/q = 2 - 1/4
q3 = 2q - 1/4q
q3 = 8/4q - 1/4q
q3 = 7/4q
q3 = 1.75q
Trying this result...
Incorrect.
I just want to point out that I'm almost completely certain that the mistake is mine somewhere along the line. Just saying that the answer I came up with happened to be incorrect, not saying that your advice is off or that. I do appreciate you helping me at this ungodly hour.
I can't see where you've gone wrong, but it is.
It may be easier to first solve for L concentrating on the added particle.
ungodly hour? :smile:
Couldn't you see my Avatar?
:rolleyes:
