Electric current in a rotating ring
3 replies · 11K views
Elysium
I'm currently stuck on this question on the image attachment. Any help would be definitely ppreciated.
Ok, so from what I understand, it asks what is the current that passes through the fixed line.
For part (a), I see that the current is 'discontinuous', and I'm not enitrely sure how to solve it.
For part (b), I multiply the charge density [tex]\lambda = \frac{Q}{\pi a}[/tex] with the tangential speed of the ring [tex]a \omega[/tex]. That would give me the charge over time, right? I believe I should of done this part with differentials though with a segment [tex]dQ = \lambda dr[/tex].
In the first problem you simply want to consider how much charge is passing through the indicated arc per unit time. In other words, don't use the derivative formula, use [tex]I= \Delta Q / \Delta t[/tex]. The simplest would be to choose delta t as one period. How much charge passes through that arc in one period?
Your part b seems valid to me.
-Dan
The full [tex]Q[/tex] of course, neglecting the bits on both poles that just spin.
So that would make [tex]Q / T[/tex] and
[tex]\omega = \frac{2 \pi}{T}[/tex]
[tex]T = \frac{2 \pi}{\omega}[/tex]
So that means the answer is:
[tex]I = \frac{Q \omega}{2 \pi}[/tex]
Ok so that's the same answer as question (b). I guess that makes sense since they both have the same amount of Q passing through the same period. So what's the difference? One is done by substitution and the other by multiplying the density with the tangential speed?
