Electric field at a point within a charged circular ring
68 replies · 10K views · last reply
vcsharp2003 said:
Is this integral doable without using approximations and numerical analysis?
Nope I don't think there is an analytical solution, cause wolfram can't find it either.
Ok. Then, I guess a qualitative answer is the best answer in this situation.
I think we have done a serious mistake regarding ##\cos a##, it becomes negative for a specific range of ##\theta## so it is not always ##\sqrt{1-\sin^2a}## but it becomes ##-\sqrt{1-\sin^2a}## as well. This depends on the position of the point P.
That's my mistake.
Yes, for all infinitesimal elements on lower arc, we will have an obtuse angle ##\alpha##, while, the same angle will be acute or 90 degrees for elements on top arc.
Delta2 said:
All the books and notes I 've read, like Griffiths, use cylindrical symmetry as I know it.
So please explain to me what it is that you "know".
I taught the undergraduate EM course from Griffiths and still have no idea what you are talking about. In particular what is the difference between axial and cylindrical symmetry ? A few sentences should suffice.
Did you mean that there is no method available to solve the integral?
vcsharp2003 said:
From above argument we can conclude that electric field at P is not zero but pointing radially inward.
Let me consider a point P', radially opposed to P. If I applied the same reasoning, I would conclude the field at P' points radially inward. Therefore, we should have a negative charge (sink) at the center but I can't see that charge.
I am not sure if your reasoning is correct. If it's correct, then a positive charge has electric lines of force emanating from it which must be directed towards a negative charge. We know this is not true. A positive charge can exist by itself and have its own electric field independent of a negative charge being paired with it.
At the center the goes squirting out symmetrically along the +/- z axis. ( The z axis being the axis of symmetry.) So this is OK. Look it up
By convention, field lines start at positive charges and end at negative charges. If I understood your reasoning correctly, at any point inside the ring (except the center) the field points radially inward. Thus, we should have a negative charge at the center.
How about electric field due to an isolated positive charge?
I'd say there are no isolated positive charges. Negative charges must be somewhere, perhaps very far away.
Delta2 said:
This is one of the cases where wikipedia (and you) are wrong. The definition I know requires invariance both in ##z## and ##\phi##. Anyway I think you have to agree with me that this cylindrical symmetry you propose is of no use with Gauss's law in integral form.
Do you have a reference for that?
Apart from one related to GR, all the items I could find online regard cylindrical, circular, azimuthal and axial symmetry as interchangeable terms.
I agree it would be more natural to define cylindrical as also implying translational symmetry along the axis, but the GR item was the only one which seemed to imply that.
Then, there should no electric field at point P. Is that what you're hinting at? Even if electric field is radially outward it would not make any sense since electric lines of force cannot end on positive charge.
My view on this is that there is a 3 dimensional electric field existing due to the ring and the lines of force from the ring will spread in a 3 dimensional manner. Lines of force go inwards from the ring towards C and then curve out towards the axis of the ring as the line approaches the point C. I am not good at depicting it through a diagram, but something like below is how the lines of force would be in 3 dimensional situation about the axis of the ring. The field in the space around the ring is going to be complex, but below diagram looks at the part of the lines of force that appear to be converging at C. They will bend outward towards the ring's axis. Sort of like a funnel pattern on each side of the ring.
Here's a decent video (though a bit long at 13mins) deriving the field at a point inside a charged ring...
Yes this is correct for both +z and -z (it is also symmetric up-down). The lines eventually diverge from the z axis and far away it all looks like that of a point charge. I have never seen a pleasant analytic treatment for the near field.
Check post #23.
Can you give me an example in Griffiths where this axial/cylindrical symmetry is used together with Gauss's law, cause the two examples you gave just won't do for reasons I explained in previous post of mine.
I must recognize muy previous posts had a flawed reasoning. The video proved me wrong and intuition can fail.
Post #23 still says objectively nothing. If you cannot even explain your objection, I shall value your opinion appropriately.
Post #23 says that the cylindrical symmetry I know has invariance with ##z## as well with ##\phi##. You know it only with invariance to ##\phi##. If that's objectively nothing and doesn't explain my objection then ok, I would say that your eyes can't see what you don't want to read.
@vcsharp2003, check the video by @Steve4Physics at post #45, it has a more clever way of calculating ##\cos a## than using sine law.
P.S it seems that even with the video approach we end up with the same result as at post #21, the only difference is that we don't need the absolute value as I had noted. It is of these strange cases in math where you do two mistakes and you end up with the correct result ,lol.
I did not understand what you meant. Your definition of cylindrical symmetry is extraordinarilly restrictive: only infinitely long right cylinders are included. As mentioned above
yours is not the customary definition of cylindrical symmetry. You are welcome to use your own idiosyncratic definitions. You are not welcome to define the rest of the community as incorrect.
Good to clear this up.
It might not be the customary definition, but in my opinion the rest of the community is incorrect and the fact that they use many different names for it (axial, azimuthal, cylindrical, circular) proves that the community doesn't know what they talk about.
Cylindrical symmetry is the symmetry the cylinder has, and it is symmetry both with respect to z and ##\phi## not only with ##\phi##. Period. The community is simply wrong on this. (Mad scientist talking :P).
Thankyou for the excellent video.
Not sure how to interpret "yours" in the above. You are addressing Delta2, yes? In the post of mine you quote, I was saying nearly all the online references I could find agree with you.
Yes of course he is addressing me, he is just using you as his lawyer :P.
Research assistant?
  • Haha
My strategy in answering the original OP is to start with the sphere and show how the differential element of the field at point P exactly cancels for opposing differential rings such as the rings through points ##BB_1## and ##CC_1##. Then show for the 2D case of a charged ring they don't cancel thus avoiding messy integrations.
We know the integration for the whole sphere cancels at P but is the assertion that corresponding pairs of differential ring elements defined by the chords ##BC## and ##B_1C_1## also exactly cancel true?
That's a good approach, but it would not be quite enough to show that the same choice of pairing does not cancel; you would need to show that for this or some other pairing the net field is always the same way.
