Electric field between two parallel plates
58 replies · 6K views
meher4real
Can't find the solution for this problem.
Wish i do know the equation.
[New poster has been reminded to show their best efforts to work the schoolwork problem when starting a homework thread]
My question is : An electron beam with velocity vector v = (0; 0.6x10^8 ;0) m.s enters between two oppositely charged plates parallel to the xz plane.
- How large is the areal charge density on the plates when the electric field between the plates stop the beam at a distance of 10mm ?
- Determine the voltage for the plate spacing of 25mm ?
hutchphd said:
Please tell us what level course this is for and indicate your thoughts about how to solve this.
I study Mining of Mineral Resources (Geology-Master Degree)
- I think that the question is tricky because the majority of electric field type of questions i found on the internet mention the q charge and they're different from this problem.
Is this an assigned problem for a particular class? What tools can you bring? For instance what does the electric field look like between two charged parallel conducting plates?
I've tried with the equation a=q/EM => a=qU/md
But none of U or q is available.
What is the q charge for an electron? I am sure you can find that on the internet.
Maybe what you found on the internet is different, but the question is not tricky. Read the problem carefully. The electric field stops the beam. Make a drawing showing the electric field lines and the velocity of a single moving electron in the beam. Whatever one electron does, all the electrons in the beam do.
The real trick is in asking the right questions that will lead you to the answer. Here are two to get you started.
What can you say looking at this picture? What must be true if an electron, moving at 0.6×108, stops over a distance of 10 mm? I will stop here and leave asking the remaining questions to you. There is no magic formula that will give you the answer. You have to put it together (with help).
Thank you guys for your interest but you have to know that I'm not a physicist, I'm a geologist.
Before i come here i did some research to find a similar problems, all of them them have the electron leave the parallel plates.
The question is not attached with a picture to know how it works. The problem is exactly what i mentioned.
hutchphd said:
Geologists are allowed to learn physics!
Who is posing this question? It is rather specific, and requires knowledge of the physics.
I meant that you don't have to learn everything.
It's a homework, I've finished three problems today (2 about waves and 1 optic) but this one is difficult for"me" (geologist).
Maybe I can remind you the formula $$E=\frac{\sigma}{\epsilon_0}$$ where E is the electric field between the plates and ##\sigma## the surface (or areal) charge density.
Also do you remember the work-energy theorem?
Picking random formulas and solutions off of the Internet is not a good strategy for learning.
The electron enters a region with a uniform electric field, and is subject to a constant retarding force. What is the equation for that force given the electric field in that region?
And using the mass of the electron, what is the deceleration of the electron in that region? How long does it take for it to stop?
What do you think about using Capacitance formula ?
C = q/V = e0x(A/d)
C : Capacitance
V : Voltage
q : electric charge
e0 : permitivity of vacuum
A : plate area
d : distance between plates
C = q/V = e0x(A/d)
Another tip would be for you to check out the LaTeX tutorial link in the lower left of the Edit window. It helps you to post math equations in online forums like the PF. :smile:
[tex]C = \frac{q}{V} = e_0\frac{A}{d}[/tex]
C = q/V = e0x(A/d)
I don't think that would be helpful. Let's simplify the problem, you have an electron with initial velocity ##v_0=0.6\times 10^8m/s## that enters an electric field and stops after traveling distance ##d=10mm##. Can you determine the strength of the electric field E (i suppose the mass and charge of the electron is given too).
Apply Lorentz's Law ?
F = qv x B
Thank you for your response.
There are two formulas :
E=F/q=kq/r^2 => F=Eq ?
V=U/q=W/q=Ed=kq/r ?
It might be the case that you haven't been taught the concept of the work of the force, in which case we ll have to do this via deceleration and kinematics equations as berkeman suggests at post #12.
E=14.4x10^-6 right ?
Er, i don't know, all i was planning to do was to guide you to find the right equation and then you could plug in the numbers to find the exact value.
Can you tell us how did you arrive at that number? All the intermediate steps?
Understood.
k = Coulomb's constant = 9x10^9
q = electron charge = 1.60x10^-19
E = F/q = kq/d^2 = 14.4x10^-6
The formula E=kq/d^2 is not correct for this problem. That is the electric field from a particle having charge q at distance d from the particle. In this problem the electric field is due to the surface charge density of the plates, not due to the electron.
I asked you a question about the work of the force F=Eq (E is our unknown here which we will try to find from the other data given and q is the charge of electron). Can you answer that question?
  • Skeptical
You have a constant force F=Eq that acts over a distance of d(=10mm). What is the work of this force. The next step will be to equate this work with the change in kinetic energy of the electron over the distance of d=10mm. And from that equation you ll find E.
Delta2 said:
Have you been taught the concept of work and the work-energy theorem? Please at least answer this question...
I have no clue about Electromagnetism.
I'm thinking about Coulomb's Law
F = kqq/r^2
Work and Work-Energy theorem is Classical Mechanics.
No Coulomb's law won't help you here because as I said before the electric field is not due to point particles but due to the surface charge density of the parallel plates.
