Electric Field Conseptual Question
The electric field, denoted as E, is defined as the force experienced by a positive test charge divided by the magnitude of that charge. In the case of a uranium nucleus containing protons, the electric field direction is away from the nucleus. This is due to the repulsive force that protons exert on other positive charges, establishing a convention that the electric field points in the direction of the force experienced by a positive test charge.
  • Understanding of electric fields and their mathematical representation (E = kq/r²)
  • Knowledge of vector fields and their properties
  • Familiarity with the concept of force between charged particles
  • Basic principles of electrostatics
  • Study the concept of electric field lines and their representation
  • Learn about Coulomb's Law and its application in electrostatics
  • Explore the concept of electric potential and its relationship with electric fields
  • Investigate the behavior of electric fields in different materials and their effects
Students preparing for physics exams, educators teaching electrostatics, and anyone interested in understanding the principles of electric fields and forces between charged particles.
JayDub
Hey There, I am studying for my exam here coming up in two weeks and I came across a question with electric field. Now I can figure it out (E = kq/ r^2) but I was wonder which direction does it travel in? For example if the question was something like: A uranium nucleus contains x protons, what is the direction of the electric field from this nucleus? Either away from the nucleus or towards it. I know that is is away from the nucleus, but why is that? Thank you.
Josh
Definition
1. A vector field, usually denoted by E, defined as follows: at a given time and at each point in space the force experienced by a positive charge (sometimes called a test charge) at that point divided by the magnitude of the charge, taken to be sufficiently small that it does not affect the positions and velocities of all other charges. The set of all vectors thus obtained is the electric field, although this term is often used for its value at any given point. ... (http://amsglossary.allenpress.com/glossary/browse?s=e&p=15")
It's simple, the electric field is in the direction of force experienced by a small positive test charge. Hence, if protons repel positive charges (force away from the nucleus), so it points away. Convention and definition is the reason.
  • · Replies 22 ·
  • · Replies 32 ·
