Electric field due to arc shaped thin rod
  • Thread starter Thread starter microdosemishief
    Electric charges
The discussion revolves around calculating the electric field due to an arc-shaped thin rod. Participants are exploring the implications of symmetry in the electric field's direction and the mathematical expressions for the electric field components derived from charge elements along the arc.
  • Participants discuss the symmetry of the problem and the resulting direction of the electric field. There are attempts to derive expressions for the electric field components, particularly questioning the use of trigonometric functions in the denominator of the integrals. Some participants are clarifying the relationship between the distance to the charge elements and the components of the electric field.
The discussion is active with participants questioning each other's reasoning and assumptions about the expressions used for the electric field. There is a focus on understanding the correct application of distance in the electric field equations, and some participants are seeking clarification on why certain methods yield different results.
Some participants express confusion regarding the implications of their results, particularly in relation to the behavior of the electric field at specific angles. There is an ongoing examination of the assumptions made about the geometry of the problem and the nature of the charge distribution.
microdosemishief
Please see image
Coulomb's Law (dE=kdQ/r^2)
My attempt: due to symmetry along x-axis, net E is only along x^hat.
dQ = λ dl = λ (R dθ)
for each dl, the x component of distance from dl to the origin is Rcos(θ)
Hence, E_x = \int_{-θ_0}^{θ_0} k(λ R dθ)/(Rcos(θ)^2 = kλ/R \int_{-θ_0}^{θ_0} sec(θ)^2 dθ = 2kλ/R tan(θ_0) along negative x^hat
But the correct answer has sin(θ_0) instead of tan(θ_0)
For the element of charge ##dQ## shown, how would you write an expression for ##dE## at the origin?
How would you write the x-component of ##dE##?
I wrote that in my question
What was your reason for writing the denominator of the integrand as ##(R\cos \theta)^2##? This is not correct.
To find ##E_x## due to the entire charge ##Q##, you need to understand that ##E_x = \int dE_x## where ##dE_x## is the x-component of the field vector ##\overrightarrow{dE}## due to an arbitrary element of charge ##dQ##.
So, first, think about the vector ##\overrightarrow{dE}## at the origin produced by ##dQ##. You should draw the vector ##\overrightarrow{dE}## at the origin in a diagram and write an expression for the magnitude, ##dE##, of this vector.
Next, think about how you can write an expression for the x-component, ##dE_x##, of the vector ##\overrightarrow{dE}##. Then you will be ready to set up the integration ##E_x = \int dE_x##.
Yes and dE = kdQ/r^2 so the denominator is r^2 where r = Rcos(θ) squared, because dE_x is Rcosθ distance away
No. Let's forget dEx for now. Just concentrate on dE.
dE is the magnitude of the electric field vector dE at the origin O produced by the charge dQ in the diagram in post #2. In the general formula dE = kdQ/r2, what would you use for the distance r in this case?
R
I just read the textbook answer but I want to know why my answer is wrong and not just a different method to the same answer
R
yes
Your answer is wrong because you can't get the x-component dEx by replacing R in the denominator of dE by Rcosθ.
Note that Rcosθ < R when θ≠0. So, kdQ/(Rcosθ)2 is greater than kdQ/R2 when θ≠0. That is, your expression for dEx is greater than the expression for dE. But the component of a vector cannot be greater than the magnitude of the vector.
I don't understand why you say that "dEx is Rcosθ distance away". Both dE and dEx are associated with the same point, namely the origin:
In what sense is dEx located a distance Rcosθ away?
Your answer $$E=\frac{2k\lambda}{R}\tan\theta_{0}$$ is wrong because for a quarter circle ##\left(\theta_0=90^{\circ}\right)## it implies that the electric field at the center will be infinite which doesn't make sense. The field is finite in the range ##0<\theta_0<2\pi.##
##Rcos\theta## is x component of vector ##\vec{r}## not ##d\vec{E}##, where by ##\vec{r}## i mean vector that starts at the origin, and points do ##dQ##.
The electric field from a charge element ##dq=\lambda d\theta## is a vector ##d\vec E## which has magnitude $$dE=\frac{kdq}{R^2}=\frac{k\lambda d\theta}{R^2}$$ because the distance between the element and the point of interest is ##R##. All elements ##dq## are at the same distance ##R## from the center of the arc. The magnitudes of their contributions ##d\vec E## are the same but their directions are different. To find the net field you need to add all elements ##d\vec E## as vectors, which means that you add all the x-components together and, separately, all the y-components together. That's called superposition.
So what are ##dE_x## and ##dE_y## if the magnitude is ##dE## as given above?
On edit
If you insist on using vector ##\mathbf r##, you can start formally from the general expression for the electric field at position ##\mathbf r## due to a point charge ##Q## at position ##\mathbf r'##, $$\mathbf E=\frac{kQ(\mathbf r-\mathbf r')}{|\mathbf r-\mathbf r '|^3}.$$ Then substitute
##\mathbf r=0##; ##~\mathbf r'=R\cos\theta~\mathbf{\hat x}+R\sin\theta~\mathbf{\hat y}##; ##~Q=\lambda d\theta## and integrate. You will get the same answer.
