easybakeoven
- 1
An annulus (disk with a concentric hole) has inner and outer radii of R1 and R2 respectively, and uniform surface charge density of \sigma. the annulus lies in the xz plane with the y-axis centered in the hole.
a.) using the most basic expression of point charge electric field as a starting point, derive an expression for the electric field E at some distance Y above the annulus along the +Y-axis.
E=kQ/r^2
I started working on the problem, and I think that the equation I've come down to for the electric field in the y direction may be close to right...
E_y=K\lambda2\piy*[-1/(r^2+y^2)^(1/2) + 1/(r^2+y^2)^(1/2)]
Is this close to right? I tried to work the problem by looking at a small linear slice of the annulus, and then rotating that around the y-axis
E=kQ/r^2
