Electric field of a non uniform charge of a cylinder
The discussion revolves around the electric field of a long solid cylinder with a non-uniform volume charge density defined by the function ρ = Ar². Participants are exploring how to calculate the total charge contained in a segment of the cylinder and the electric fields both inside and outside the cylinder at specified radial distances.
  • Participants discuss the integration needed to find the total charge and question the validity of the electric field formula used for the inside of the cylinder. There is an exploration of applying Gauss' law to derive the electric field inside the cylinder, with some participants seeking clarification on the integration process and the regions involved.
Some participants have provided guidance on the application of Gauss' law and the need to reconsider the assumptions made regarding charge distribution. There is a recognition that the original formula for the electric field inside the cylinder is not applicable due to the non-uniform charge density.
Participants note that the charge density increases with radius, which affects the calculations for the electric field. The discussion includes attempts to clarify the setup of the problem and the necessary equations for integration.
TwinCamGTS
A very long solid cylinder of radius R = 4.2 cm has a non-uniform volume charge density along its radial dimension, given by the function ρ = Ar2, where A = +2.2 µC/m5.
a)How much total charge is contained on a 1 m length of this cylinder?
b)Outside: What is the electric field at a radial distance of 5.2 cm from the axis of the cylinder?
c)Inside: What is the electric field at a radial distance of 3.2 cm from the axis of the cylinder?
use gauss law to find the electric field
total charge = ρ * area of the cylinder = A*(r^2)*2∏*r*L = A*2∏*L*r^3
electric field inside the cylinder E = (ρ * r)/(2 * εo)
electric field outside the cylinder E = ( λ )/(2∏ * r * εo)
first of all we need to find the total charge of contained on a 1 m length of the cylinder
the volume charge density is changing by the radial dimension ( the radius).
so, to find the total charge for the cylinder with radius 4.2cm,
we need to do the integral for the charge equation
so total charge is
∫A*2∏*L*r^3 dr , the result is (.5∏*A*L*r^4)
plugin the value of A, L , and r we get (1.07532E-11 C)
electric field outside the cylinder E = ( λ )/(2∏ * r * εo) i got (3.71887 N/C)
I have problem with this one, based on the equation, electric field inside the cylinder
E = (ρ * r)/(2 * εo) , i just plug in everything into the formula
E = ((A*r^2)*r)/(2*εo)
= ((2.2E-6)*(.032^3))/(2*(8.85E-12))
= 4.07285 N/C
but the answe is wrong.
I just wonder, do i have to redo the integration for this part again? E = ((A*r^2)*r)/(2*εo)
I thought if i do the integration, isn't it become voltage?
thank you for your time and reply
Hello.
The formula you used in part (c) for E is not valid for this problem.
Try Gauss' law to derive E inside the cylinder.
like ∫(Ar^2)*r*dr = A∫r^3*dr
then plug everything back to the original equation?
Not sure I'm following you here. Does your integral represent charge in some region? If so, what region?
What equation is the "original equation"?
Since this looks like a problem for the application of Gauss' law, start with the statement of Gauss' law. Then think about how you would apply this law to the problem of finding E inside the cylinder.
The formula you used in part (c) for E is for the case where the charge density is uniform inside the cylinder. If you look back in your notes or textbook at the derivation of this formula using Gauss' law, it should provide a guide for setting up Gauss' law for your problem.
Almost: like ##\int_0^r \rho dV = 2\pi A\int_0^r r'^2 r'dr'##
[edit]drat, crossed TS reply again. Over to you, TS!
And: I take it the "equation, electric field inside the cylinder" is for a homogeneous charge distribution, which we don't have here. Right, Twin ?
i got it, thanks...so the density charge gets higher as the radius get bigger.
so i integrated the parts Qenc = ∫(A*r^2)2∏*r*H*dr r=Radius of gauss
put into the gauss law
EA=Qenclosed/εo
E(2∏*r*H)=(∫(A*r^2)2∏*r*H*dr)/εo
rearrange everything and cancel some of the variable (jump to final equation)
E=(A*r^3)/(4*εo)
Nice. Good work!
  • · Replies 36 ·
9K
