Electric field of infinite plate
9 replies · 3K views
Dell
2 infinite plates are placed one next to another in a V formation with an angle β between them, they have charge densities of σ1 and σ2. what is the magitude of the field betweein them.
ϕ=[tex]\oint[/tex]EdA=EA
ϕ=[tex]\frac{q}{ϵ}[/tex]=[tex]\frac{σA}{ϵ}[/tex]
E1=[tex]\frac{σ1}{ϵ}[/tex]
E2=[tex]\frac{σ2}{ϵ}[/tex]
E=E1+E2
lets make our x-axis parallel to plate 1 giving E1 a 0 value on x axis
Ex= 0 + [tex]\frac{σ2}{ϵ}[/tex]*sinβ
Ey= [tex]\frac{σ1}{ϵ}[/tex] + [tex]\frac{σ2}{ϵ}[/tex]*cosβ
|E|2=|Ex|2 + |Ey|2
=([tex]\frac{σ2}{ϵ}[/tex]*sinβ)2 +([tex]\frac{σ1}{ϵ}[/tex] + [tex]\frac{σ2}{ϵ}[/tex]*cosβ)2
=[tex]\frac{1}{ϵ}[/tex]*(σ22sin2β + σ12 + σ22cos2β + 2(σ1)(σ2)cosβ )
=[tex]\frac{1}{ϵ}[/tex]*(σ22(sin2β + cos2β ) + σ12 + 2(σ1)(σ2)cosβ)
|E|2=[tex]\frac{1}{ϵ}[/tex]*(σ12 + σ22 + 2(σ1)(σ2)cosβ)
which is almost right except that in my answers there is a second possible solution that
|E|2=[tex]\frac{1}{ϵ}[/tex]*(σ12 + σ22 - 2(σ1)(σ2)cosβ)
where does this minus come from? originally i thought it might be because of a possible negative charge density but surely if that was so the sign would be part of σ and come automatically when i plug in values
i see the latex codes came all messed up, meant to read:
Ex= 0 + (σ2/ɛ)*sinβ
Ey=(σ1/ɛ) + (σ2/ɛ)*cosβ
|E|^2=|Ex|^2 + |Ey|^2
and at the end after calculations come to
|E|^2=(1/ɛ)*(σ1^2 + σ2^2 + 2(σ1)(σ2)cosβ)
where there is meant to be a second option of
and i can't see where from. originally i thought it might be because of a possible negative charge density but surely if that was so the sign would be part of σ and come automatically when i plug in values
correct, so does that mean that if 90<β<270 then i will use the minus option? could i then also say |E|^2=(1/ɛ)*(σ1^2 + σ2^2 + 2(σ1)(σ2)|cosβ|)
I think all it means is that there are 2 solutions depending on the angle of β.
Your representation above ignores the second solution where cosβ is (-).
what are the 2 options? is it
|E|^2=(1/ɛ)*(σ1^2 + σ2^2 + 2(σ1)(σ2)cosβ) when (cosβ>1)
and
|E|^2=(1/ɛ)*(σ1^2 + σ2^2 - 2(σ1)(σ2)cosβ) when (cosβ<1)
if so than can i not just say that it is
and then cos will always be positive, in effect that is what i am doing anyway, taking minus the value of the negative cos
looking back at the original question and the one i posted, i see that in the original the 2 plates formed an X like shape whereas i wrote in my post a V shape, originally i never thought anything of it but now looking back i think that the (- cosB) is for the area between the top and bottom points of the X on either side whereas the ( + cosB) is for the area between the top 2 points or bottom 2 points, (when B is an acute angle,) or alternatively the opposite(when B is obtuse).
is this a correct presumption?
An X configuration does simultaneously create 2 regions (4 actually, but 2 sets of 2).
yes but is one the -cos option and the other the +cod option?
One governs acute angles and the other obtuse doesn't it?
