Electric field of infinitely long parallel wires
20 replies · 15K views
E&M
Two infinitely long parallel wires separated by a distance 2d, one carries uniform linear charge density of [tex]\lambda[/tex] and the other one carries an uniform linear charge density of -[tex]\lambda[/tex], find the electric field at a point distance z away from the middle point of the two wires.
E(left wire) = [tex]\lambda[/tex].K .integration (1/r^2). dr
E(right wire) = - [tex]\lambda[/tex].K .integration (1/r^2). dr
r = (x^2 + d^2 + z^2)
dr = dx
i don't know what should be the limit of integration and i don't know if whatever i did is right or not.
hey, I have attached a figure. I thought this might make your life a little bit easier...i think you have to calculate potential and then calculate E, otherwise it's going to be hard. I think the x and z components cancel each other. so, you will only have y component of electric field. good luck.
Do you know the solution for a single infinite wire carrying charge density [itex]\lambda[/itex]? If so, you can use the superposition principle and avoid having to carry out any integration.
i know the solution for single infinite wire at a point z distance above the center of the wire but since, here we also have to consider y direction, I am not sure how to do it.
Well, what is the solution "for single infinite wire at a point z distance above the center of the wire"?
K. 2 (lambda) / z for the wire with charge density = positive. lambda
Good, so for that solution z is the distance from the wire...What is the distance from the point (0,0,z) to either of the two wires in the new problem?
The distance would be the hypotenuse in the following diagram...
k
|z \
|___\_______>j
d
wouldn't it?
if u were asking distance from the center of the wire then it's going to be (y^2 + z^2) ^.5 where y = d right?
so, is the E simply going to be K. 2 (lambda) / (d^2 + z^2)^.5 along the direction of (d^2 + z^2) and then when we consider two wires, z components are going to cancel and we calculate and add the y components?
Yes, the magnitude of E for the wire with +lambda is just K. 2 (lambda) / (d^2 + z^2)^.5. And the magnitude of the other wire is (-)K. 2 (lambda) / (d^2 + z^2)^.5. What are the directions of each of those fields?
for the individual wires, their x components cancel and they only have y and z components, but if we consider both of the wires, their z components cancel as well and then there will be only y component left pointing towards the wire with -lambda charge density.
Yes, so what is the y-component of E for each wire? (Remember that E points along the hypotenuse in the above diagram)
individual y component is going to be K* 2 * (lambda) * cos( angle between hypotenuse and d) / (d^2 + z^2)^.5.
= K* 2 * (lambda) * d / (d^2 + z^2)
Net y component = 2* K* 2 * (lambda) * d / (d^2 + z^2)
