Electric field strength problem
The discussion centers on calculating the electric field strength at a point 0.01 meters to the left of charge q2, with given charge values of q1 = 6.0e-6 C, q2 = 1.5e-6 C, and q3 = -2.0e-6 C. The calculations confirm that the electric field due to q1 and q2 cancel each other out, resulting in a total electric field of E3 = 2.00e7 N/C at the specified point. Additionally, the discussion touches on conceptualizing the force on a point charge in relation to the electric field, emphasizing the formula E = F/q for calculating force.
  • Understanding of electric field concepts and calculations
  • Familiarity with Coulomb's law and electric force equations
  • Knowledge of charge interactions, including positive and negative charges
  • Basic proficiency in algebra for manipulating equations
  • Study the application of Coulomb's law in various charge configurations
  • Learn about electric field lines and their representation
  • Explore the relationship between electric fields and forces on charges
  • Investigate the effects of multiple charges on electric field strength
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to electric fields and forces on charges.
chemkid
Here is my solution. I completed this problem to the best of my ability and I am asking for someone to check and correct my solution if possible. I am not sure if my answers are correct, although and my thinking might also be flawed :confused:
q1= 6.0e-6C
q2= 1.5e-6C
q3=-2.0e-6C
The charges are arranged as such:
O......O...O
q1----0.03m---q2---.02m--q3
The problem is to find the electric field at a point 0.01 meter to the left of q2.
Here is my solution: ( I am ommiting units in calculation for clarity, units are given in answers)
E1y = 0
E1x = Ke q1/r^2 = 8.99e9 * 6.0e-6/.02^2 = 1.35e8 N/C
E2y=0
E2x= Ke q2/r^2 = 8.99e9 * 1.5e-6/.01^2 = 1.35e8 N/C
E3y = 0
E3x = Ke q3/r^2 = 8.99e9 * 2e-6/.03^2 = 2.00e7 N/C
Summing the x components I see that E2x and E1x cancel each other out with respect to the arbitrary point 0.01m to the left of q2. So, I am left with a total electric field of E3 at a point 0.01 cm to the left of q2= 2.00e7 N/C.
Is this correct?
There is a second part of this problem that asks about the force on a point charge placed at the point given its charge of -2.00e-6C. Oddly enough I find finding forces a bit more straightforward. Conceptually I would set it up as a standard charge triangle problem. Seeing as there are no Y components I can just take the sum of the X components in the same way as I did the electric force? Not looking for calculations on the second part of this problem just a conceptual hint on how to go about it, but I would appreciate if someone checks my physics and calculations for the first part of the problem where I have given my answers.
Thanks in Advance,
chemkid
Your calculations for this are correct. As for finding the force on a point charge, go back to the definition of an electric field.
E=F/q
And rearrange for F. (Once you have the field, you only need to plug in a value for q to find the force).
hmm..
what if 1 of the charges is negative?
would the answer still be the sum of field strengths or would it require the subtraction of the negative charge's field strength?
