Measuring electric field vs magnetic field
The discussion revolves around measuring electric and magnetic fields, particularly in the context of electromagnetic signals from cell phone towers and their potential impact on health. Participants explore the relationship between electric field measurements and corresponding magnetic field values, as well as concerns regarding exposure to these fields in residential areas.
  • One participant questions whether the magnetic field value decreases proportionally with the electric field when measured before and after reflection from a metal fence.
  • Another participant provides a method to convert electric field measurements to magnetic field values, noting that this conversion is valid only in free space.
  • Concerns are raised about the location of measurements and the potential for interference from reflected waves, suggesting that the measured electric field could vary significantly based on position.
  • A participant discusses the practical reasons for measuring only electric fields, emphasizing the convenience and calibration aspects for users.
  • There are claims regarding the power reduction associated with electric field strength and its implications for human exposure, with references to the absorbed energy being minimal compared to normal human metabolism.
  • Some participants express skepticism about the health risks associated with low-intensity electromagnetic signals, suggesting that known health risks should be prioritized over concerns about RF exposure.
Participants express differing views on the significance of magnetic field measurements in relation to electric fields, and there is no consensus on the health implications of exposure to electromagnetic signals from cell towers. The discussion remains unresolved regarding the exact relationship between the fields and their potential effects.
Participants note that the impedance of the environment can affect measurements, and that the discussion is complicated by the variability of electromagnetic fields in different locations. There is also mention of the need for caution in interpreting RF hazard information due to its approximate nature.
aphelix
Hello.
Sorry. I am not a physicist and I have very superficial knowledge of the subject. I would like to ask a question about the practical field. I only have a device that measures the electric field. When I measure the signal coming from a cell phone tower before it is reflected from a metal garden fence (completely covered, not wired), I read 3 v/m. When I measure it after reflection at the appropriate angle, I see that it has dropped to 1 v/m. Has the magnetic field value (ex. microtesla) also decreased by the same amount? Or could the magnetic field be different?
Thanks.
Yes. To convert E to H, you divide by ## 377~\Omega ##, to convert to B you divide by the speed of light. For 1 V/m I get H = 2.65 mA/m and B = 3.34 nT.
WernerQH said:
Yes. To convert E to H, you divide by 377 Ω,
But only in free space. The impedance of the regions near the ground or any conductor will not be 377Ω.
Firstly, why would you need to know that?
Then. where are you measuring this 1V/m? The measured value is likely to be due to the resultant of the incident and reflected wave and could have maxes and mins all over the region. Also the polarisation will probably vary with position.
I have a Wavecontro SMP2 device, equipped with a high-frequency signal probe capable of measuring signals up to 8 GHz. However, it can only measure electric fields. When I position myself directly to the cell tower, just in front of a metal garden fence, the measured value reads 3 V/m. If I step back 5 meters from the fence to my house walls, and face away from the tower towards the fence, the reading decreases to 1 V/m. But the tower couldn't be seem from there.
The primary concern is that my son's room is located there, and I want to determine if it is affected by the signal. The fence is approximately 4 meters high and is made of metal.
when I measure the electric field right in front of his room's window(towards fence), the reading registers as 1 V/m.
The power reduces to 1/9 when the field drops by a factor 3. For the case of 1 V/m the radiated power is E×H = 2.65 mW/m^2. Only a fraction of that is absorbed by the human body (depending on frequency), but even if it were 100%, the absorbed energy would be five orders of magnitude below the heat produced by the normal human metabolism (about 100 W).
Also, if you or your son have a mobile phone or wifi, the power from these will be comparable to that from the tower inside your house.
Moreover, whenever you are outside in your garden you will be exposing yourself to a much, much more harmful type radiation that is a major cause of cancer: namely UV radiation from the sun.
There are very good, practical reasons for this. The main one is that the majority of users are only interested in one field reading. When assessing signal strength for comms, the standard E field measurement is convenient and easy to reproduce and allows calibration of measuring equipment. The same thing also applies to measuring Hazards. I suspect this is the context of your post.
I searched around for some figures about acceptable levels of RF for humans and was pretty swamped with information as it's different for all frequency bands and different levels are chosen in different administrations. You will need to do your own homework on this, I'm afraid. Many people worry about exposure to RF from local transmitters and there are many cranks involved with the argument so be careful what you believe.
As you already have the measuring device, you could walk all over and around your home and see what happens to the readings - also go right up close to the mast. The beams are usually shaped so that there is very little power directed towards local ground. Your results could be interesting.
Is there a local protest group against that particular mast?
Good luck.
However, this does assume free space propagation and free space impedance. No big deal as long as you don't expect better than ball park values for any actual risk. RF hazard is a very approximate business.
Despite decades of study, there is little-to-no good evidence that cell phone and other electromagnetic signals are harmful at the low intensities that are used in communication. Unless the military is pointing a high-power radar system at your house from point-blank range you are better off worrying about known health risks, not imaginary ones.
Thread locked.
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 41 ·
  • · Replies 42 ·
