Electric fields between point charges
AliTheAlienTV
Member warned that we strongly discourage images of the problem statement and work done.
Question 2c: I've attempted the question, I've got the magnitude right but I got the angle wrong. I don't understand why the value of the components are swapped around.
Electric fields
Scanned exam page showing parts (a) to (c) of Question 2 on electric fields, with Figure 1: a right triangle with point A at +6.0 nC at bottom left, point B at -4.0 nC at top right, 300 mm base, 400 mm vertical side, and point P at the right angle corner.
Worked solution showing resultant field at P: vector diagram with PB up, AP right, resultant RP diagonal, then right triangle with AP = 225, PB = 599, angle theta; Pythagoras gives RP = 639.9 N/C and tan(theta) gives 69.41 degrees to AP.
I’m guessing it’s just convention to reference the angle from the positive x-axis instead of the y-axis.
To nitpick your solution should say “angle from the line AP” not “to the line AP”
  • Screenshot of a web browser showing a MyExams past-paper question labelled Question 2c, medium, 3 marks, asking to calculate the magnitude and direction of the resultant electric field at point P.
