Electric immersion water heater time
4 replies · 5K views
rgold
The mechanical equivalent of heat is 1cal=4.18J. The specific heat of water is 1cal/g*K and its mass is 1g/cm^3. an electric immersion water heater rated at 400 W should heat a liter of water from 10C to 30C in about how much time
R=v/i
power=v*i
I know the answer is 3.5 minutes but i do not know how to get there. I am pretty lost.[/B]
on Phys.org
R=v/i
power=v*i
Work out the units. What is a watt? How many grams of water are in 1 liter?
BTW, the formulas in Section 2 won't help you with this problem, since you don't know voltage, current, or resistance.
im still confused i know that a watt is joules per second and that 1000 grams of water in a liter but how do i connect everything?
R=v/i
power=v*i
you should calculate amount of heat required to raise the water from t1 to t2 given -then calculate the time taken by the heater to provide that heat-
heat req.= related to( massxsp. heatx temp diff ) by calorimetric equation
rgold said:
im still confused i know that a watt is joules per second and that 100 grams of water in a liter but how do i connect everything?
You need to go back and study the SI system some more. 1 liter contains way more than 100 grams of water.
