Electric potential at point x on the axis of a ring of charge density eta
The discussion focuses on calculating the electric potential at a point on the axis of a circular disk with a surface charge density defined as \(\eta = cr\), where \(c\) is a constant. The user seeks to express the potential \(V\) in terms of the total charge \(Q\) and the radius \(R\) of the disk, while eliminating the constant \(c\). The solution involves integrating the charge density over the disk to relate \(c\) to \(Q\) and \(R\), ultimately leading to a definitive expression for the electric potential without the constant.
  • Understanding of electric potential and charge distribution
  • Familiarity with integration techniques in calculus
  • Knowledge of the formula for electric potential due to point charges
  • Concept of surface charge density in electrostatics
  • Study the derivation of electric potential from continuous charge distributions
  • Learn about the integration of charge density over geometric shapes
  • Explore the relationship between surface charge density and total charge
  • Investigate the application of Gauss's Law in electrostatics
Students and educators in physics, particularly those focusing on electromagnetism and electrostatics, as well as anyone involved in solving problems related to electric potential and charge distributions.
Bng1290
Electric potential at point x on the axis of a ring of charge density "eta"
A circular disk of radius R and total charge Q has the charge distributed with surface charge density [tex]\eta[/tex] = cr, where c is a constant. Find an expression for the electric potential at distance z on the axis of the disk. Your expression should include R and Q, but not c.
[tex]\eta[/tex]=cr where c is constant
V=(1/4pi[tex]\epsilon[/tex])(Q/r)
V=[tex]\Sigma[/tex]Vi
So what I did was to sum all Vi and i was able to pull (1/4pi[tex]\epsilon[/tex]) and (1/sqrt(z^2+R^2) out which leaves me with Q left in the sum which I know i need to relate to [tex]\eta[/tex] in some way. The problem I'm having here is that I just don't understand how to work with [tex]\eta[/tex]=cr in such a way as to get rid of the constant c in my answer.
I feel like I'm not grasping this problem as a whole so any help would be wonderful. Thanks!
To eliminate c, since \eta = cr, you can integrate the charge density over the disk to compute the total charge, Q. This should give you c in terms of Q and R.
Nice! Thanks so much!
