Electrical Potential Energy Problem
In the electrical potential energy problem, a metal sphere loses 10^13 electrons to another initially uncharged sphere, resulting in a potential energy of 7.2x10^-2 Joules. The charge of the first sphere is calculated by multiplying the number of electrons by the elementary charge, 1.60x10^-19 Coulombs. The user struggles with the formula involving the Coulomb constant and the distance between the spheres, initially using the same charge for both. A suggestion is made to assume the first sphere was neutral before losing electrons and to convert the charge to Coulombs for both spheres. Following this advice leads to a successful resolution of the problem.
Embermage
Hello,
I've been trying and trying to do this problem for quite a while now, and I can't seem to get an answer which agrees with the book.
In a charging process, 10^13 electrons are removed from a metal sphere and placed on a second sphere that is initially uncharged. Then the electrical potential energy associated with the two spheres is found to be 7.2x10^-2 Joules. What is the distance between the two spheres?
I figured that one metal sphere would then end up with a charge of 10^13 electrons (so I multiplied that by 1.60x10^-19 to get the charge of all the electrons in the sphere). But there is no charge given for the second sphere! I was using the equation:
(q1*q1/r)Coloumb Constant (8.99*10^9) = Energy
Nothing seems to work. Even using the same value for q1 and q1 doesn't produce the correct answer, which the book feels is 0.32 meters.
I'm stuck... thanks so much for any help!
Try making the assumption that the sphere that lost the electrons was initially neutral in charge. Don't forget to convert electrons to coloumbs twice, once for each charge!
cookiemonster
Thank you very much... it worked like a charm.
