What is the relationship between electrical power and torque in a generator?
The relationship between electrical power and torque in a generator is directly linked to the load applied; as the current demand increases, the generator must exert more torque to maintain power output. When a generator is loaded, the back electromotive force (EMF) decreases, which affects the mechanical power conversion. The induced current generates an opposing magnetic field, requiring additional torque from the prime mover to overcome this resistance. This phenomenon aligns with Lenz's Law, which states that induced currents create magnetic fields that oppose the initial magnetic field. Understanding these principles is crucial for comprehending generator operation under varying loads.
Evil Bunny
Lets say we have a fixed voltage output on a generator... As we load it down (require more current to flow out of it), the generator needs to apply more torque to supply the power.
Why? What is resisting the rotor from turning?
in this case(the motor is loaded), will the mechanical power converted by the motor be smaller though the intensity of current has increased??
since P(mechanical)=E'*I where E' is the back emf, E' decreases when the motor is loaded?
Curl said:
there's the answer.
That's actually not an answer. It's a reading assignment...
Here's my guess. We induce a current onto a wire with a magnetic field. As current is flowing through that wire, it creates it's own magnetic field that is opposite in polarity to the magnetic field that is being induced onto it... These fields oppose each other which requires more torque from the prime mover to overcome it..?
bump... Is this correct?
Is the induced current creating a magnetic field that is opposite in polarity that makes it resist the current that was originally induced... Which makes them oppose each other, like the prime mover is now trying to overcome the opposing magnetic fields as if you were trying to force two north poles of magnets together?
Is this right?
Yes.
Do a search on Lenz's law and it basically says the same thing.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
