Is it Safe to Touch Wall Outlet Plus?
  • Thread starter Thread starter david90
    Electrical
Touching the positive terminal of a wall outlet without a ground connection generally won't result in a shock, as electricity requires a potential difference to flow. If the body is at the same electrical potential as the terminal, no current will pass through. Birds can perch on power lines without getting shocked because they do not create a path to ground, while wet animals like squirrels can provide a conductive path and risk electrocution. Insulating materials, like rubber-soled shoes, can further reduce the risk of shock. However, caution is advised when dealing with household electrical systems, as even small voltages can be dangerous.
david90
if u only touch the + of ur wall outlet would it shock u? What if ur feet are not touching the ground or carpet?
Electricity requires a potential DIFFERENCE to flow. If your entire body is at the same potential, no current flows anywhere.
Potential is also a quantity that only has meaning in terms of a difference. You're free to select the "zero" of potential anywhere you'd like.
If you touch the + terminal of a 1000V battery, you're at potential of 1000V with respect to the - terminal. Of course, you're also at a potential of 0V with respect to the + terminal. Both descriptions are perfectly valid and correct.
All that being said, I'd advise you not to go grabbing the hot wire in your house's electrical system -- 120V can jump across sizeable air gaps, and you'd have a really hard time truly isolating yourself from ground.
- Warren
The answer lies in what happens to birds sitting on a power line.
If you do not provide a path to ground or nuetral you will not get shocked.
Will i get shock if I'm wearing tenis shoes and touch the + at the same time? Since shoes are good insulator, i shouldn't get shock right? Does cerment conduct electricity? I'm guessing all things conduct if the potential is high enough.
So how come birds doesn't get shock when pirch on power lines? Is it possible for them to get shock even though they are not touching the ground or other wires?
Birds don’t get shocked when they perch on power lines because they do not provide a good path for the electricity to get to the ground. As said above electricity requires a potential difference to flow. A physical analogy is close to this. Let's say you wanted to drop a ball from some height to the floor. You let the ball fall. I will fall until it hits the ground. Applying this to electricity. Have you ever seen a squirrel running across a power line after a storm? Personally I haven't but I can guess. The wet squirrel unlike the bird can provide an excellent path for the electricity when crossing from the power lines (high potential with respect to ground) so some other object, tree or pole (ground). Anyway there would not be much let of the squirrel. Lesson to be learned, ahhh "better squirrel trap"?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
