Electricity and magnetism: Electric Field for Two Long Charged Lines
The discussion centers on calculating the electric field generated by two infinitely long charged lines, each with a linear charge density of +λ Coulombs/meter, separated by a distance of d meters. The electric field E at any point along one line due to the other is given by the formula E = λ/(2πε₀d). The derivation involves dividing the line into small segments, applying Coulomb's law, and using trigonometric substitution for summation. Additionally, the force per unit length between the two lines is to be determined as part of the problem-solving process.
  • Understanding of Coulomb's law
  • Familiarity with electric fields and linear charge density
  • Knowledge of trigonometric substitution techniques
  • Basic principles of electrostatics
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the concept of linear charge density in electrostatics
  • Explore the application of trigonometric substitution in physics problems
  • Investigate the forces between charged objects in electrostatic contexts
This discussion is beneficial for physics students, educators, and anyone studying electrostatics, particularly those focusing on electric fields and forces between charged lines.
Silentwhale
Given two very long lines each is charged with linear density +lambda Coulombs/meter. The two lines are separated by a distance of d metres.
A) show the electric field E, at any point along one of the lines due to the other line is
E = lambda/(2 (pi)(epsolon o)(d))
(Note: divide line into small segments, apply coulombs law, note the direction, perform summation using trigonometric substitution)
B) write down the force per unit length between the two lines.
Q= lambda/distance
dq = lambda (dx)
dE = kdq/x^2
Please show your work so far
