Electricity current question , nodes
The discussion revolves around a homework problem related to an electrical circuit, specifically focusing on calculating currents through resistors and determining potential differences between nodes. The scope includes theoretical and practical aspects of circuit analysis.
  • Homework-related, Technical explanation
  • One participant requests guidance on how to approach the problem without seeking a direct answer.
  • Another participant suggests using the superposition method due to the presence of multiple power sources, indicating that the circuit should be analyzed one source at a time.
  • A follow-up question asks whether the circuit should be divided into three individual circuits for analysis.
Participants appear to agree on the need for a methodical approach to the problem, but there is no consensus on the specific steps to take, as the discussion remains unresolved regarding the best way to split the circuit.
abs123456
1. For the circuit shown in Figure Q1 calculate:
(i) The magnitude and direction of the current that flows through Rl ,
(H) The magnitude and direction of the current that flows through RS.
(iii) The potential difference between nodes Q and R
(iv) An equivalent circuit between terminals Q and R allowing V3 to be replaced
with a current source.
Circuit has been attactched
Could someone please explain how i would do this question. Thanks
We aren't supposed to just give you the answer.
You have multiple power sources, so start by using the superposition method which means looking at one source at a time and then adding them all up at the end.
Once you've started with that if you need any help, don't hesitate to ask for more.
Hi mate, i didnt want the answer, just some advice/tips on how i should go about doing this question
So do i have to split the circuit into 3 individual ones?
