Electromagnetic Field in Empty Space
An electric field can exist in empty space even without charges, though its strength would be zero in such a case. This concept means that while the field is mathematically present, it does not exert any influence until charges are introduced. When a charge enters this space, it disturbs the field, creating a non-zero electric field. Additionally, any movement of electric charges generates a magnetic field, which propagates through empty space at the speed of light, radiating energy. Understanding these principles is crucial for grasping the behavior of electromagnetic fields in physics.
Arman777
Insights Author
Our Professor said there will be still an electric field in empty space even without charges.Hows that possible.Space-time has a some quantum property that acts like this ?
If there are no charges at all in the whole universe, there won't be an electric field. But there are charges in the universe. You have an electric field even in regions without charges due to charges elsewhere.
I know but he meant something else ..
He said aomething like this.Theres electric fields or some field and ıf charge comes there like a postive one It disturbs the field.And makes our normal things it was something like that I don't quite remember
You may have misunderstood your instructor. I would ask him or her for clarification directly.
Ok I will
Well, technically "the electric field" is defined everywhere in space even without charges. Its strength is zero in that case. Usually this is called "no field", although mathematically the field is there.
Make sense then...So ıf there's no charge in space-time its just there but "mathematically"
If we put a charge in space time charge makes a electric field so it become "real" ?
If we have charges somewhere, the value of the field becomes non-zero.
A field that is zero everywhere doesn't do anything, at least in classical physics.
Likes Arman777
I see..Thanks
Any movement of electric charges somewhere, will result in a magnetic field due to the current flow and a change in the local electric fields. Those E and M fields will propagate outwards at the speed of light through empty space. Energy is being radiated in the direction of wave propagation.
  • · Replies 25 ·
21K
