Electromagnetic induction question, coils and magnets
The discussion centers on electromagnetic induction, specifically the behavior of a coil connected in a closed circuit when a magnet is moved inside it. When the magnet is moved into the coil, it induces an electromotive force (emf) due to a change in magnetic flux. However, once the magnet remains stationary inside the coil, the magnetic field through the coil's windings does not change, resulting in no induced emf. The coil will produce voltage via self-induction only after the magnet stops moving, but this voltage will eventually decay to zero as the current dies away.
  • Understanding of electromagnetic induction principles
  • Familiarity with Faraday's Law of Induction
  • Knowledge of magnetic flux and its relationship with coils
  • Basic concepts of self-induction in electrical circuits
  • Study Faraday's Law of Induction in detail
  • Explore the concept of magnetic flux and its calculations
  • Learn about self-induction and its effects in closed circuits
  • Investigate the behavior of inductors in AC and DC circuits
Students of physics, electrical engineers, and anyone interested in understanding the principles of electromagnetic induction and its applications in circuits.
Hannah7h
Say you have a coil connected in a closed circuit. You then move a magnet inside of the coil and it remains stationary inside of the coil. Is the magnet, even though it is stationary, still inducing an emf in the coil or is it not? I'm guessing it doesn't induce an emf in the coil because there is no change in flux linkage, but I'm not too sure.
Thank you for any help
I am not sure what you are asking. How can the magnet both move and remain stationary?
Do you mean that both the magnet and the coil are moving at the same velocity so that they have no relative motion? Or do you mean that the magnet remains at rest and the coil moves relative to the magnet?
Oh sorry! I meant you move the magnet INTO the coil and then it remains stationary inside of the coil
That's correct. Since the magnetic field through the coil's windings isn't changing, there is no induced emf in the coil.
Ok cool, thank you
Ah, ok. So there will be a voltage while it is moving into the coil, but once it stops the flux is no longer changing in time and so the voltage will be 0.
Yep this is what i thought, thank you very much
If the coil is in a closed circuit, then when the magnet stops moving, the current will die off, and the coil will produce voltage via self induction.
No, once the magnet stops and the current has died away, there is no longer any EMF.
True, but it takes some amount of time (after the magnet stops moving) for current to go to zero. The inductance of the coil prevents current from dropping to zero instantaneously.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 60 ·
