Electromagnetic Induction Question
9 replies · 3K views · last reply
Eisen
Can someone please tell me why the magnetic field makes the electrons flow round the coil in a generator? Does the force of the magnetic field have to go in the same direction as the coil?
A voltage is induced in the coil, and it is this voltage which pushes electrons around the coil and through the external circuit. In order to induce a voltage in a conductor, the conductor must cut through or cross the magnetic flux lines.
So if you are wearing a gold watchband, running cross-country from north to south will not induce a voltage in your watchband because you are moving along a magnetic line of the Earth (these imaginary lines are drawn around the Earth from the North Pole to the South Pole). But if you run east-west you are cutting across the Earth's magnetic lines and causing a voltage to be induced in your watchband (providing you orientate it to best effect).
Even so, the voltage is too small for you to measure.
Why does cutting the lines of the magnetic field cause electrons in the copper wire to be deflected in the right direction? When the wire goes through the magnet it is at a right angle to the magnetic field-
Handwritten sketch of a vertical wire passing between an N pole and an S pole, with arrows showing magnetic field lines pointing down and electron flow arrows pointing up along the wire. Key on the right: down arrow labelled direction of magnetic field, up arrow labelled direction of electrons.
See what I mean? So how do the electrons get pushed up vertically by a magnetic field that seems to be horizontal?
I haven't got an answer yet, can someone please reply with an answer?
It is a good, but hard question. Try to google it, or maybe wikipedia got an answer. What I have learned, and it might not be correct, is that electromagnetism will affect the free electrons in a conductor when applying a force as when moving the conductor through the electromagnetic field. Free electrons in the conductor will gather on one side of the wire. When you load this wire the elerctrons can flow back to the other end with lack of electrons. But as long the wire is moving through the electromagnetic field the electron flow will continue.
I hope someone have a better answer.
Vidar
For that answer, you'll have to ask the Creator. :smile:
That gives maximum induced voltage. At other angles, you still get induced voltage, but of lesser magnitude.
Direction of movement, direction of magnetic lines, and the induced current are all vector quantities and are all perpendicular to each other: an x-y-z 3-dimensional space.
Ask the creator, you mean God? Come on, surely one of the mere mortals on here has the answer? :biggrin: But seriously though, isn't there a theory to explain this?
Are you looking for something like this? http://en.wikipedia.org/wiki/Lorentz_force
The lorentz force describes the force on a charged particle by electromagnetic fields. A charged particle feels a force in a direction that is perpendicular to a magnetic field line. I would hit up the above article and browse around to learn more if you are interested.
Thanks for your replies, I am continuing to investigate electromagnetic induction.
