What Determines the Frequency and Wavelength of Electromagnetic Radiation?
In summary, electromagnetic radiation can originate from various sources such as atomic transitions, accelerating charged particles, and scattering. The frequency and wavelength of the radiation are determined by the energy of the photon in the case of atomic transitions, the cyclic frequency of the charge in the case of accelerating charged particles, and the type of scattering in the case of scattering. There are also other possible sources of EM radiation, such as transitions between bound states and scattering, which can produce a discrete or continuum spectrum.
Shukie
95
A question that I reckon will be fairly simple for you guys. Electromagnetic radiation originates from electrons going down different energy levels, correct? But then what determines the frequency and wavelength of that radiation?
I could be completely off-base, but I'm inclined to imagine the orbit of the affected electron as a disk rolling away from the atom in all directions simultaneously at the speed of light. The wavelength is then the speed of light divided by the period of the affected orbit .
Regards,
Bill
This is not entirely accurate.
While you do get EM radiation upon an atomic transition, this isn't the only means to create it. Any accelerating charge can produce the same thing. A charge oscillating produces EM radiation as well.
In an atomic transition, the "frequency" f corresponds to the energy of the photon, i.e. E=hf. When you create EM radiation via accelerating charges, the frequency corresponds to the cyclic frequency of that charge.
Zz.
Thanks a ton, are these three (atomic transition, accelerating charge and oscillating charge) all possible 'creators' (excuse my English) of EM radiation or are there even more?
Kind regards,
Erwin
I agree.
An electron orbiting an atom might as well be an oscillating charge to a distant observer.
With respect to atomic transition, does the energy of the photon not necessarily equal the change in energy of the orbiting electron??
Regards,
Bill
l
yes but an electron doesn't draw any particular orbit around the nucleus in an atom actually, it is rather "moving around" than anything else. Moreover, an atomic transition (for an non hydrogenoid atom) changes the whole electronic configuration and this is quite complicated to discribe with simple "images" in reality.
What do you mean by "moving around"?
The electron orbits each have their own period, and re-orient (e.g. "move around" on their shell) to maintain the equilibrium of forces over time.
Yes - for an atom with more than one electron, the loss of one electron affects what passes for a state of equilibrium among all that remain.
Regards,
Bill
Regards,
Bill
But this isn't your ordinary "orbit" as in the classical sense, because that would cause it to radiate in a stable orbit. We see no such thing in the ground state of an atom. So already such classical picture doesn't work.
There is a https://www.physicsforums.com/showpost.php?p=862093&postcount=2" in this General Physics sub-forum.
Zz.
I didn't mean to imply that it was. Surely, the intersection of a cone and an electron shell would not fit the classical sense.
I didn't say the orbits were "stable" either - I claimed that they re-orient with respect to time. In this scenario, the charge need not apear at two points on a line every half period (oscillate).
Regards,
Bill
Regards,
Bill
I have no idea what you just said here.
Recall that you responded to my "oscillating charge" post by writing this:
So you certainly were equating an atomic orbital with an oscillating, or accelerating charge, which is incorrect.
If you have a published physics paper that is describing what you just wrote here, please post it. Otherwise, I've never heard of such a thing and it is purely speculative. And I believe you know already what that implies.
Zz.
As far as I know there is no evidence that such shells exist, this is much more the contrary actually.
In principle the electron in the ground state for example can be found in the whole volume around the center of the nucleus with a given probability, I'm very curious to know how you retrieve this result within your "shell theory".
Kind regards,
Erwin
There are lots of ways to generate radation: transitions between (electronic, vibronic, rotational) bound states produces emission with a discrete spectrum. Accelerating charged particles produces continuum radiation (oscillating is a form of acceleration). Scattering also produces continuum radiation.
Regards,
Bill
I think you are using the concept of electron orbitals a little too literally.
I've read the whole thread and I'm surprised no one has given what I would consider
a clear answer. The Schroedinger picture of the hydrogen gives a very clear picture of the energy level transition in which the production of radiation is accoreding to Maxwell's equations.
Look at the transition from the 2p (excited) to the 1s (ground) state. Each of those states has a charge distribution (or "cloud") which is stationary with time. But the phase of each charge cloud has a complex frequency, different for each state. When we picture the atom in a mixture of those two states, the phases interfere with a beat frequency equal to the difference of the two frequencies. As a result, the location of the charge cloud oscillates about a central plane. As a small dipole antenna, we would classically calculate that it radiates energy at a certain power level. So it would take a certain amount of time to shed the excess energy from the exicted state to the ground state. In fact, this is the same time spoken of in quantum mechanics as the lifetime of the excited state; or from another point of view, it tells us the spectral linewidth for that transition.
I don't believe there are any instances of radiation in quantum mechanics that can't ultimately be analyzed as a case of oscillating charge (or magnetic moment).
It is simply my interpretation of an electron with a precessional orbit, and how it might apply to what we were discussing.
However, since you seem to be of the opinion that I am breeching forum guidelines, I will cease contributing to this thread to avoid further transgression.
Regards,
Bill
What is electromagnetic radiation?
Electromagnetic radiation is a form of energy that is propagated through space in the form of electromagnetic waves. It includes various types of energy, such as radio waves, microwaves, infrared radiation, visible light, ultraviolet radiation, X-rays, and gamma rays.
How does electromagnetic radiation interact with matter?
When electromagnetic radiation meets matter, it can be either reflected, absorbed, or transmitted. The interaction depends on the type of radiation and the properties of the matter it encounters. For example, visible light is reflected by a mirror, absorbed by a dark-colored object, and transmitted through glass.
What are the sources of electromagnetic radiation?
Electromagnetic radiation can be produced by various sources, both natural and human-made. Some natural sources include the Sun, stars, and lightning. Human-made sources include electronic devices, such as radios, TVs, and cell phones, as well as power lines and nuclear reactions.
What are the applications of electromagnetic radiation?
Electromagnetic radiation has numerous applications in our daily lives. Some examples include communication (radio and TV waves), heating food (microwaves), medical imaging (X-rays), and sterilizing objects (UV radiation). It is also used in scientific research, such as studying the composition of stars through their emitted radiation.
What are the potential risks of electromagnetic radiation?
While electromagnetic radiation has many beneficial applications, it also has potential risks. High levels of radiation exposure, such as from X-rays or nuclear reactions, can be harmful to living organisms. Additionally, some research suggests that long-term exposure to low levels of radiation from cell phones and other electronic devices may have health implications, although this is still debated among scientists.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
