Electromagnetism - The distance from point a to point b
15 replies · 2K views
Jon Blind
So I want to know the distance to 2. The proton is at v=0 at the 1.
We know that:
q=1.602*10^-19 point 1
L=1mm
v=1.1*10^6 at point 2
F=1.44*10^-12 at point 1
[/B]
E=(1/4πε)*(q/r2)
ΔV=∫E*dr=(1/4πε)*q∫(1/r2)=(1/4πε)*q*(1/r2-1/r1)
ΔU=ΔK=mv2/2
ΔK=mv2/2=ΔV*q=q*(1/4πε)*q*(1/r2-1/r1)
3) The attempt at a solutionI can't seem to calculate the distance. I don't know where I've gone wrong.
Exactly and I'm trying to find out r2.
According to my calculations r2=2.28*10^-13 but that seems way too little?
What did you use for the mass of the proton? Also, did you convert ## L ## to meters? Also you need to solve for Q. You can do that because itt tells you the force ## F ## at point 1.
Yes, the mass of the proton is 1.673*10^-27
Epsilon=8.854*10^-12
and q=1.602*10^-19
and q=1.602*10^-19
I see one mistake. You assumed the two q's were equal. See also my edited previous post. You need to solve for ## Q ##.
So Q=F/E ??
I'll give it a try and calculate it now, thankyou very much.
Jon Blind said:
So Q=F/E ??
## F=\frac{Qq}{4 \pi \epsilon_o r^2} ##. They give you ## F ##, ## q##, and ## r ##. You need to compute ## Q ##.
5.87*10^-4m
THANKYOU! Freaking hell I was so confused
Jon Blind said:
5.87*10^-4m
Compute ## Q ## in Coulombs. You need this number for the remainder of the calculations. The answer you gave is incorrect.
How is that possible?
ΔK=mv2/2=ΔV*q=q*(1/4πε)*Q*(1/r2-1/r1)
Q=1.00*10^-9ΔK=mv2/2=ΔV*q=q*(1/4πε)*q*(1/r2-1/r1)
(mv^2*epsilon*m*4*pi)/(2*q*Q)=1/r2-1/r1
(1.673*10^-27)*)((1.1*10^6)^2)*4*pi*(8.854*10^-12)/(2*(1.602*10^-19)*(1.00*10^-9))=1/r2-1000
1/r2=1702.97
r2=5.872*10^-4
1/r2=1702.97
r2=5.872*10^-4
Close, but your final term should read ## \frac{1}{r_1}-\frac{1}{r_2} =1000-\frac{1}{r_2} ## . ( ## r_2>r_1 ##). ## \\ ## Once you correctly solve for ## r_2 ##, you then need to compute the distance ## D=r_2-r_1 ##.
In that case r2 should be= 0.00337m
r2-r1=0.00237
Charles Link said:
Now solve for ## D ##. See my edited post #12.
Yep I saw it, and I edited my post and did it ;)
r2-r1=0.00237
