Electromagnets, high voltage/amps, and RF
  • Thread starter Thread starter SkiesOfBordom
    Electromagnets Rf
Aiming RF signals at a high-powered toroidal electromagnet will not alter the signal's propagation, as the magnetic field does not affect photons. The interaction would be similar to that with any metal, inducing eddy currents that generate heat in the material. No RF signals would be emitted from the magnet; the field is symmetric and does not create a lesser field on one side. The discussion emphasizes that the static magnetic field is irrelevant to the RF signal's behavior. Overall, RF signals and microwaves will behave consistently regardless of the presence of a magnetic field.
SkiesOfBordom
I was wondering what the reaction would be if you aimed RF signal/s into a high powered circular electro-magnet (i think the proper term is a toroid ?). I ask because its too dangerous for me at the moment to conduct experiment. (220v @ 20amps).
would the signal be shot out the side that has the lesser field? If i remember correctly, one side of this kind of electromagnet has a greater field.
I have a lot of things tinkering inside my head, and would like to voice them.
I'm afraid I have no idea what you're talking about. What would happen if you aimed a strong beam of, say, microwave radiation at a toroidal magnet?
(A toroidal magnet has a field that is symmetric across the plane of the toroid, so neither side has a lesser field.)
As far as the microwaves are concerned, the magnetic field is irrelevant -- photons do not carry charge, and thus are not affected by magnetic fields. The microwaves would interact with a toroidal magnet in the exact same way that they would interact with any other toroidal piece of metal. They would induce eddy currents, which would heat up the metal. No signals would be "shot out" of anything.
- Warren
The effect on the RF signal would be the same whether the lump of metal were a magnet or not a magnet. The static magnetic field would not affect the propagation of the RF signal.
ooo ok. thanks for the responses.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
