Do electrons flow in one direction in magnets?
Electrons do not flow in one direction in magnets; rather, the magnetic fields are generated by the angular momentum and intrinsic spin of electrons within the atoms of the material. In non-magnetic materials, the magnetic moments of electrons cancel each other out, while in magnets, these moments align, producing a net magnetic field. The discussion clarifies that while permanent magnets do not rely on electric currents, electromagnets do, as the flow of electrons creates the magnetic field. The magnetic behavior of materials is influenced by their electron configuration and temperature, affecting their ability to be magnetized.
  • Understanding of electron configuration and magnetic moments
  • Knowledge of the Pauli exclusion principle
  • Familiarity with the concept of magnetic domains
  • Basic principles of electromagnetism
  • Research the effects of temperature on magnetic properties of materials
  • Learn about the Pauli exclusion principle and its implications for magnetism
  • Explore the differences between permanent magnets and electromagnets
  • Investigate the role of electron configuration in determining magnetic behavior
Students of physics, materials scientists, and anyone interested in understanding the fundamental principles of magnetism and electron behavior in various materials.
Kannonball
Do electrons continuously flow from north to south pole in magnets. If yes, does this continue to happen when the magnet is attracted or repelled by another magnet or to a ferrite?
A normal magnet like the ones you would stick on a refrigerator do not depend on electric currents to generate their magnetic fields. Instead they use the angular momentum of electrons in their orbitals AND the intrinsic spin of the electrons to generate it. In a non magnetic material the magnetic fields of each atom do not line up with each other, resulting in each field being canceled out by other fields. In a magnet the atoms are aligned so that most of the north poles point one way and most of the soulth poles point the other, each field adding with the other to produce a large noticeable effect.
You are exactly right OP, the flow of the north and south pole magnets causes the magnetic domains to align themselves. The magnet is not the metal itself, it is the substance circulating in the metal.
He is not asking about the north and south pole of the magnetic field, he is asking about the flow of electrons causing the field. Which is incorrect, as there is no net direction of electron flow.
Again, incorrect. The electons in the atoms and molecules that make up the magnet are what cause the magnetic fields.
However, in an Electromagnet, which is a wire coiled into mulitple loops, the flow of electrons (current) IS the cause of the magnetic field.
In any magnet there is indeed a magnetic current flow. If it were the metal itself then we would not be able to change the poles or make the material not a magnet anymore.
See here: http://en.wikipedia.org/wiki/Magnetism
Particularly this part of it:
Ordinarily, the enormous number of electrons in a material are arranged such that their magnetic moments (both orbital and intrinsic) cancel out. This is due, to some extent, to electrons combining into pairs with opposite intrinsic magnetic moments as a result of the Pauli exclusion principle (see electron configuration), or combining into filled subshells with zero net orbital motion. In both cases, the electron arrangement is so as to exactly cancel the magnetic moments from each electron. Moreover, even when the electron configuration is such that there are unpaired electrons and/or non-filled subshells, it is often the case that the various electrons in the solid will contribute magnetic moments that point in different, random directions, so that the material will not be magnetic.
However, sometimes — either spontaneously, or owing to an applied external magnetic field — each of the electron magnetic moments will be, on average, lined up. Then the material can produce a net total magnetic field, which can potentially be quite strong.
The magnetic behavior of a material depends on its structure, particularly its electron configuration, for the reasons mentioned above, and also on the temperature. At high temperatures, random thermal motion makes it more difficult for the electrons to maintain alignment.
If magnetism is caused by a substance flowing in a metal, why aren't all metals capable of being magnetized?
In a related note, do you know where I can get some phlogiston cheap?
Your comments are appreciated and understood
  • · Replies 32 ·
