Electron oscillating in vacuum
An oscillating electron in a vacuum will lose energy due to the creation of electromagnetic radiation, which propagates energy away from the charge. The interaction of the moving charge with the vacuum state of electromagnetic fields leads to damping effects. This results in the electron behaving as a damped harmonic oscillator, necessitating energy input to maintain its oscillation. The discussion highlights the interplay between charge motion and electromagnetic field dynamics. Overall, an oscillating electron cannot sustain its motion indefinitely without external energy.
qwertyuiop23
My question is a relatively short one. Simply put it is:
"Will an electron oscillating in a vacuum lose energy?"
My thought comes from does the presence of the moving charge create electromagnetic fields. I have no idea how you could get the charge to oscillate but perhaps in the neutral point between two other stationary charges could create it but I am not sure.
Cheers
Lance
Yes, as you stated the oscillating charge creates electromagnetic radiation which propagate power from the charge out to space. In addition, the charge couples to the vacuum state of electromagnetic fields. This coupling also gives rise to dampening if I recall correctly. So just assuming an oscillating charge and quantum electrodynamics, you end up having a damped harmonic oscillator that requires energy input to keep going.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
