Electron traveling between two plates
  • Thread starter Thread starter talaroue
    Electron Plates
An electron traveling at 4.91×10^7 m/s between two parallel charged plates requires a specific magnetic field strength to avoid deflection. The relevant equations involve balancing the electric force (Fe) and magnetic force (Fm), leading to the relationship Fe = qE and Fm = qVB. The electric field (E) can be derived from the voltage (V) and the distance (d) between the plates, using E = V/d. The final equation for the magnetic field strength (B) simplifies to B = V/(s*q*V), where s is the distance between the plates and q is the charge of the electron. The discussion highlights the importance of using the correct formulas and unit conversions to arrive at the correct answer.
talaroue
An electron travels with speed 4.91×107 m/s between the two parallel charged plates. The plates are separated by s=1.47 cm and are charged by a 203 V battery. What magnetic field strength will allow the electron to pass between the plates without being deflected?
----------+------- < postive plate
>>>>O < electron
----------(-)------- < negative plate
I thought that
Fnet=Fe+Fm
Fe= electric force
Fm=magnetic force
Set it equal to zero o=Fe+Fm
Fe=Fm
(Kq1)/(r^2)=qVB
solve for B...that didn't work what am I doing wrong?
talaroue said:
Fe=Fm
(Kq1)/(r^2)=qVB
Fe is not (Kq1)/(r^2)
(Kq1)/(r^2) is E ( electric field )
Fe = E x q
So then my equation should be (Kq1q2/R^2)/qVB
You mean (Kq1q2/R^2) = qVB :wink:
Yes that's right, but it's better to use Eq = qVB
Find E, then solve for B
What charges do I use, I can tell from that equation that the charge of the plates are going to cancel out. So then...
E=VB
Kq/r^2=VB
B=KQ/(R^2*V)
do i assume is half of the distance between the plates?
For two parallel charged plates, E = V/d, where V = voltage across the parallel plate and d = distance between the plate
oh so instead of using E=KQ1Q1/R^2 I should use E=V/D?
Yups
For some reason it didn't worl
Why? Have you converted 1.47 cm to m?
Here is my work...
Fe+Fm=0
Fe=-Fm
Voltage/s(distance between plates)=qV(velocity)B
B=Voltage/(s*q*V)
The charge (q) has canceled out and even if they haven't, you can subs it with the charge of an electron which is 1.6 x 10^(-19) C
right that's is what q I used...My professor had his c++ language wrong online so it wouldn't take my answer but he fixed it and my answer is right now.
