Electron traveling between two plates
  • Thread starter Thread starter talaroue
    Electron Plates
12 replies · 7K views · last reply
talaroue
An electron travels with speed 4.91×107 m/s between the two parallel charged plates. The plates are separated by s=1.47 cm and are charged by a 203 V battery. What magnetic field strength will allow the electron to pass between the plates without being deflected?
----------+------- < positive plate
>>>>O < electron
----------(-)------- < negative plate
I thought that
Fnet=Fe+Fm
Fe= electric force
Fm=magnetic force
Set it equal to zero o=Fe+Fm
Fe=Fm
(Kq1)/(r^2)=qVB
solve for B...that didn't work what am I doing wrong?
talaroue said:
Fe=Fm
(Kq1)/(r^2)=qVB
Fe is not (Kq1)/(r^2)
(Kq1)/(r^2) is E ( electric field )
Fe = E x q
talaroue said:
So then my equation should be (Kq1q2/R^2)/qVB
You mean (Kq1q2/R^2) = qVB :wink:
Yes that's right, but it's better to use Eq = qVB
Find E, then solve for B
What charges do I use, I can tell from that equation that the charge of the plates are going to cancel out. So then...
E=VB
Kq/r^2=VB
B=KQ/(R^2*V)
do i assume is half of the distance between the plates?
For two parallel charged plates, E = V/d, where V = voltage across the parallel plate and d = distance between the plate
oh so instead of using E=KQ1Q1/R^2 I should use E=V/D?
Here is my work...
Fe+Fm=0
Fe=-Fm
Voltage/s(distance between plates)=qV(velocity)B
B=Voltage/(s*q*V)
The charge (q) has canceled out and even if they haven't, you can subs it with the charge of an electron which is 1.6 x 10^(-19) C
right that's is what q I used...My professor had his c++ language wrong online so it wouldn't take my answer but he fixed it and my answer is right now.
