Electron velocity in Electric Fields
27 replies · 14K views
C6ZR1
An electron with a speed of 5.57 × 108 cm/s in the positive direction of an x-axis enters an electric field of magnitude 2.72 × 103 N/C, traveling along a field line in the direction that retards its motion. (a) How far will the electron travel in the field before stopping momentarily, and (b) how much time will have elapsed?
KE= .5mv^2
F=EQ
E=kq/r^2
W=FD
For part A I got it correct which is 0.0325m.
I solved it by first calculating KE of the particle: .5 (9.11 E-31)(5.57 E 6) [converted velocity into m/s instead of cm/s]
KE= 1.413 E -17 J
Then I calculated F, F= (1.6 E-19)(2.72 E3) F=4.352 E-16
With those two values I plugged them into W=FD and got 0.0325m
Now to find the time I used all necessary information and applied t=d/v
t=0.0325m/5.57 E 6 t=5.83 E -9 s
On the homework I entered it both in scientific notation and by the complete decimal but it keeps marking it wrong. I've gone through it several times to make sure I did not do any calculations incorrectly but I can't seem to find any.
I would really appreciate it if someone could please review my work and see if it is correct. Thanks :smile:
KE= .5mv^2
F=EQ
E=kq/r^2
W=FD
KE= 1.413 E -17 J
The electron will be subject to a constant force due to the electric field, so its motion will be that of an object undergoing acceleration (or deceleration if you wish). Because its velocity is changing, the formula t = d/v, which is for uniform motion, isn't going to work. Can you think of a formula that applies to accelerated motion? (hint: the velocity is going from its initial value to zero with constant acceleration)
Would it be Vf=Vi+at or d=Vi*t+1/2at^2?
It would. Choose the easier one to solve for t :wink:
I think I will as well. lol
a would just be 9.8, correct?
EDIT: should it be -9.8 to make t positive?
No, no gravity here, just the electric field. The object being accelerated is an electron... you calculated the force earlier...
ahhh that makes more sense. lol
So applying F=ma..
4.352 E -16=9.11 E -31 [mass of the electron] *a
a=4.77 E14 m/s^2
Does that seem correct?
EDIT: Also, when using that value, t comes out negative...
So applying F=ma..
a=4.77 E14 m/s^2
It does.
and t being negative is also fine?
No, not so fine. t should end up positive. Can you show your calculation?
using Vf=Vi+at
0=5.57E6+4.77 E14 t
t= -5.57 E6 / 4.77 E14
t= -1.25 E -8
C6ZR1 said:
using Vf=Vi+at
0=5.57E6+4.77 E14 t
t= -1.25 E -8
Is electron speeding up or slowing down? That is, is the acceleration positive or negative?
It sounds like the electron is slowing down then speeding up in the opposite direction.
oh, would that mean that there is a negative acceleration?
That's probably true, but you're only interested in the trajectory up to the point where it (momentarily) comes to a halt.
The signs of displacements, velocities, and accelerations is determined by your choice of coordinate system. If your initial velocity is taken to be positive and it's slowing down, then the acceleration must be negative...
thats makes sense, so then my t value would be t= 1.25 E -8 but my online homework is saying that the answer is incorrect :/ I am rechecking my calculations and actually trying it with D=vi*t+1/2at^2 formula. Quadratic formula here we come!
ok so with the formula D=Vi*t+1/2at^2 I applied the quadratic formula and got..
0.0325=5.57 E6+1/2(4.77 E14)*t
t=4.84 E-9 or t=-2.82 E-8
I think you'll want to check your arithmetic. 1.25 doesn't look like the result of 5.57/4.77.
That doesn't look right. There should be linear and quadratic terms for the equation. Also the acceleration still needs to have the appropriate sign!
0.0325 = 5.57x106 t - (1/2) 4.77x1014 t2
ohhhh that's what it was. ok so now after that and doing it correctly I get t= 1.197 E -8s for both values
I think you'll want to keep several more decimal places in all intermediate results if you're going to use the quadratic formula method. They can be "sensitive" to round off errors. In fact, it's a good idea to always keep a few extra digits for all intermediate results, and only round final values.
Why don't you try the "simpler" method again now that you've sorted out the acceleration sign? vf = vi - a*t
with that formula I got that t= 1.16771 E -11
Should the answers be different?
No, the answers will not be different. Your power of ten looks to be off... did you convert cm/s to m/s before doing the calculation? You should also check that you kept sufficient decimals in your acceleration value.
I'll check it tomorrow morning because I am dead tired, but I just wanted to say that I EXTREMELY appreciate your help and time. :smile:
ok I rechecked it and recalculated and here are my results:
quadratic formula: t= 1.13814 E -8 or t=1.19729 E -8
Using vf = vi - a*t: t= 1.16771 E -8
I keep redoing the math but it turns out the same. :/
This is an example of where significant figures and rounding can have marked effects on the results. ALWAYS calculate intermediate values using more decimal places than the final result requires, and round only at the end. Quadratics can be notoriously sensitive to parameter values. This particular one should end with a double root... and they should both be close to the 1.16 value. When I calculate the value using high precision values of constants for the charge and mass of the electron, and keeping full precision for all intermediate values during the calculation, I find t = 1.164 x 10-8 s.
However. Let me give you a tip that may help. When you are working on a problem that has some initial velocity vo, a final velocity of zero, and a given distance for the particle to stop, d, then rather than solve the equation:
[itex]d = v_o t - \frac{1}{2} a t^2[/itex]
Use instead:
[itex]d = \frac{1}{2} a t^2[/itex]
which provides: [itex]t = \sqrt{\frac{2 d}{a}}[/itex]
and thus only one root to contend with.
The thing is, going from some initial velocity to zero over distance d is just a time-reversed version of going from zero to that speed over the same distance! It's like "running the film backwards" -- the event takes the same amount of time to complete only the formula for the distance is simpler, dropping the initial velocity term.
ohhhhhhh now I am getting that, I didnt even think of using that equation. And this problem has taught me a valuable lesson on rounding. lol Thanks again for explaining it. :smile:
