Electronic Circuits-Compute voltage gain for OP-amplifiers
  • Context: Engineering
  • Thread starter Thread starter beyondlight
    Electronic Gain Voltage
The discussion focuses on calculating the voltage gain of operational amplifiers (op-amps) in a specific circuit configuration. The user initially miscalculated the output voltage (u_ut) and the current (i) flowing through the resistors, leading to an incorrect gain ratio. After reevaluating the circuit with the common mode voltage (v_x) included, the correct output voltage (u_o) was determined to be -u_in, resulting in a voltage gain of -1. This confirms that the gain of the op-amp configuration is indeed -1 when v_x is considered as zero.
  • Understanding of operational amplifier (op-amp) configurations
  • Knowledge of voltage gain calculations in electronic circuits
  • Familiarity with resistor networks and current flow analysis
  • Basic concepts of common mode voltage in op-amp circuits
  • Study the principles of operational amplifier feedback and stability
  • Learn about different op-amp configurations, such as inverting and non-inverting amplifiers
  • Explore the effects of common mode voltage on op-amp performance
  • Investigate advanced topics in op-amp circuit design, including frequency response and bandwidth
Electronics students, circuit designers, and engineers working with operational amplifiers who need to understand voltage gain calculations and circuit analysis techniques.
beyondlight
We got the following circuit:
http://tinypic.com/view.php?pic=1zl7xg2&s=6
u_in is input
u_ut is output
I assumed that the upper amp has voltage u_in on the positive terminal.
And that the lower amp has voltage 0 V on the positive terminal.
then i calculated u_ut but the ratio then becomes: u_in/u_ut = 0
Because the current from the upper amplifiers output terminal to the output terminal u_ut is
i=u_in/2R
which then gives us
u_ut=u_in -(i*2R) = u_in -u_in
the right answer should be -1
help please.
I would analyze it by saying the voltage on the lower input is vx, and that on the upper input terminal is uin+vx, with vx being the common mode voltage.
Otherwise you are losing all the information associated with the lower pair of R resistances.
First step: determine, in terms of the input, the voltage at the (+) input of the third op-amp.
So this is how i did it:
On the positive input for the 3rd amplifier we have v_x/2.
And i suppose that the voltage on the output terminal of the upper amplifier is v_x+u_in
The current through the resistor then becomes:
i=\frac{\frac{v_x}{2}-(u_{in} + v_x)}{R}
Then the expression for the output u_o is:
u_o=\frac{v_x}{2} - R*i = {\frac{v_x}{2}-\frac{v_x-2u_{in}-2v_x}{2R}*R}
after simplifying we obtain:
u_o=-v_x-u_in
u_o/u_in = -1 (if v_x = 0)
Have i done correct?
Which resistor? Which direction?[/color]
If we use your above expression for i, then the "-" here should be "+"
It is for the resistor after the output of the upper-most amplifier. I thought the current goes out of this amplifier and ends up at the output. So then it should be "-"
But i re-calculated this task with my method again, and got a quite different result. That turned out to be correct. I calculated without adding v_x.
The same current: i=(u_in/R)
u_out=0-Ri= -R(u_in/R)=-u_in
The gain then becomes -1.
I think this is sufficient.
