Electronic Firework Ignition System
1 reply · 8K views
dusty8683
I want to use a 50-pin cable to ignite e-matches connected to fireworks. The e-matches require about 1 Amp to ignite. The individual conducting wires in the cable are obviously very thin, and thus can't conduct a continuous 1 Amp current. My question though is this: can the very thin conducting wires safely carry 1 Amp of current if just for a fraction of a second? And how does one go about figuring out how much current is safe for short pulses through similar wires?
What you are talking about is similar to how fuse currents are calculated. The amount of current that it takes to blow a fuse depends on the amount of time that the current flows through the fuse. Take a look at a typical fuse datasheet:
http://www.cooperet.com/library/products/1608FF_Specs.PDF
The "Time Current Curve" graph is what you are asking about. I googled time current curve +wire, and got some good-looking hits. I don't have time right now to find the best hit in the list for you, but maybe look around this list to see if it helps:
http://www.google.com/search?hl=en&q=time+current+curve++wire
