Electronics (Circuit Analysis) Questions
stefan10
Problem A
http://imagizer.imageshack.us/v2/800x600q90/855/6v0c.png
Problem B
http://imagizer.imageshack.us/v2/800x600q90/853/1m2c.png
http://imagizer.imageshack.us/v2/800x600q90/34/wfe4.png
Kirchhoff's Rules/Ohm's Law
Voltage Divider Formula
[tex]V_{ab} = (V_{0}*R_{2})/(R_{1} + R_{2})[/tex]
Problem A:
I'm unsure how much information is sufficient for what the question is asking. I derived these equations, and relations for different currents:
[tex]I_{1} = I_{AB}=I_{EF}[/tex]
[tex]I_{3} = I_{BC}=I_{CD} = I_{DE}[/tex]
[tex]I_{2}=I_{BE}[/tex]
Loop 1 (Clockwise)
[tex]0 = V_{0} - I_{1}R - I_{2}R - I_{1}R = V_{0} - 2I_{1}R - I_{2}R[/tex]
Loop 2 (Clockwise)
[tex]0=V_{0} - 1/2 V_{0} - I_{3}R \ \mbox{(used Voltage Divider Eq for the voltage of GH)}[/tex]
[tex]\Rightarrow 0 = V_{0} - 2I_{3}R[/tex]
Node Equation
[tex]0 = I_{1} - I_{3} - I_{2}[/tex]
Solving these equations I get
[tex]3 I_{1} = I_{3}[/tex]
[tex]I_{2} = -2 I_{1}[/tex]
[tex]I_{3} = - (3/2) I_{2}[/tex]
So for the questions asked:
a.) V_{GH} = V_{0}/2
b.) I_{GH} = V_{0}/2R
c.) I'm not sure how to find this.
Problem B:
V Thevenin is equal to V_{GH} right? That means V_{th} = V_{GH} = V_{0}/2
R Thevenin is R parallel to R, which can be found with 1/R_{th} = 1/R + 1/R which give us R_{th} = 2/R.
I'm not as confident of Problem B as I am of Problem A.
This problem is easiest to solve by using series & parallel combinations of resistors.
For a), collapse the circuit from right to left, combining resistors as you go. You will end up with only one resistor -- this tells you the overall current from the voltage supply. Then re-build the original circuit from left to right, calculating currents and voltages as you go.
1. In problem 13, did you get something like V_be = V_o/3 ?
If so, don't you think V_gh = Vo/2 is a little strange ?
I do not understand your 1/2 V_o in loop 2.
