Electron's Speed and Electric Field
2 replies · 8K views · last reply
Soaring Crane
The voltage between the cathode and the screen of a computer monitor is 12 kV. If we assume a speed of zero for an electron as it leaves the cathode, what is its speed just before it hits the screen?
a. 8.87*10^7 m/s
b. 6.5*10^7 m/s
c. 4.2*10^15 m/s
d. 7.7* 10^15 m/s
e. 5.3*10^7 m/s
See below.
q_e = 1.60*10^-19 C
m_e = 9.11*10^-31 kg
V = (k*q)/r
r = (k*Q)/V = (8.988*10^9(1.60*10^-19)/(12,000 v) = 1.1984*10^-13 m
deltaV = (delta U)/q
U = deltaV*q = (12,000)*(1.60*10^-19 C)
F = E/q = (1.92*10^-15 j0/(1.1984*10^-13 m) = 0.01602 N
a = F/m = (0.0160 N)/(9.11*10^-31 kg) = 1.759*10^28 m/s^2
v_f^2 = v_i^2 + 2*a*x
v = sqrt[2*1.7587*10^28 m/s^2*(1.1984*10^-13)] = 6.49*10^7 m/s?
A surface is so constructed that, at all points on the surface, the E vector points inward. Therefore, it can be said that
a.the surface encloses a net positive charge.
b.the surface encloses a net negative charge.
c.the surface encloses no net charge.
d.the surface vector delta S at all points on the surface is necessarily parallel to the electric field vector E.
e.the surface vector delta S at all points on the surface is necessarily perpendicular to the electric field E.
See below.
By convention, a negative charge corresponds to an inward electric flux while a positive charge corresponds to an outward flux?
Thanks.
You're complicating the first answer with too many unknowns.
You're given P.D and the charge on the particle. What is the work done on the particle at the end of it's trip from the cathode to the screen in terms of these quantities?
Work done = delta KE
Work = q*V = 1.192*10^-15 J
Work = m/2*(v^2)
sqrt[W/(m/2)] = v_f = sqrt[1.192*10^-15 /(m_e/2)] = 6.49*10^7 m/s
Well, I'm relieved that my answer checks out.
