Electroscope experiment in vacuum
The discussion revolves around the behavior of an electroscope experiment conducted in a vacuum, specifically focusing on the phenomenon of the aluminum leaves collapsing when the pressure decreases. Participants explore the underlying mechanisms, including potential explanations related to Paschen's law and the effects of different gases on the experiment's outcomes.
  • Experimental/applied
  • One participant describes the electroscope experiment and notes that the leaves collapse abruptly at a relative pressure of around 30 inHg, raising a question about the underlying cause.
  • Another participant suggests that Paschen's law could explain the observed behavior.
  • A different participant acknowledges Paschen's law but expresses uncertainty about its applicability due to the nature of the experiment, suggesting that the abrupt collapse may indicate a breakdown phenomenon.
  • One participant mentions that in discharge tubes, discharges start abruptly as pressure decreases, hinting at similarities in behavior.
  • Another participant elaborates on the breakdown process, discussing the relationship between electric field strength, pressure, and the mean free path of electrons, proposing that the collapse is related to a chain reaction of ionization and recombination.
  • Several suggestions are made for improving the experiment to prolong the charge on the leaves, including using different gases, ensuring cleanliness, and avoiding sharp edges in the setup.
Participants express differing views on the applicability of Paschen's law and the nature of the breakdown process, indicating that multiple competing explanations exist without a clear consensus.
The discussion highlights the complexity of the electroscope's behavior in a vacuum, with factors such as gas type, pressure, and experimental setup potentially influencing the results. Specific assumptions and dependencies on definitions remain unresolved.
Readers interested in experimental physics, vacuum technology, and gas discharge phenomena may find this discussion relevant.
Dan Haronian
Hi
I am running the electroscope experiment in vacuum. This is shown in (a) in the uploaded figure . Once the aluminum leafs are charged the chamber is pump down (b). As soon the pressure decrease low enough (around relative pressure of 30 inHg) the leafs collapse to each other abruptly.
Here is a short video of the collapsing leafs:
There is still a gap between the two leafs but it's much less than in atmospheric pressure. This effect takes place every time I run the experiment.
In another experiment, the chamber is pumped down before the leafs are charged. The gap between the leafs is much smaller than that in atmospheric pressure.
Can anyone explain why?
Thank you drzoidberg,
I thought of Paschen's law as well but I am not sure because of the abrupt collapse. It looks more like some kind of breakdown. In addition there is only one charged electrode. V in Paschen's law refers to the breakdown voltage between two electrodes. Still there is an electric field between each leaf and the surroundings. So maybe some variation of Paschen's law. Paschen's law Is gas dependent. I am going to try different gasses to see how this affects the leaf collapsing.
I know that with a discharge tube, the discharge starts fairly abruptly as the pressure goes down.
The setup here is different than in a tube which Paschen's law refers to. V is the breakdown voltage between the two electrodes and d in p*d is the distance between the two electrodes. Yet, if we divide the two axis by d we get E as a function of p. E is the electric field at which breakdown takes place which is a function of the pressure. Referring to one leaf, E is proportional to 1/x^2. So the breakdown field is such that the MFP of electrons is such that they gain enough energy to ionize gas molecules. A breakdown in this case will be creation of many such ions (chain reaction) that flow to the leaf and recombine with electron on the leaf. E will diminish as the recombination progress and the overall effect will slow down. I assume that the abrupt effect where the two leafs collapse to each other (but not completely as in the video) is the chain reaction. The slow collapse of the leafs towards each other, that follows, is due to slower process of ion generation and recombination with electrons on the leaf.
Does this make sense?
I will run this experiment with He gas where the ionization energy is higher. My goal is to have the leaf stay charged for long time. Any ideas are welcomed.
Some possible approaches:
  • Pull a good vacuum before charging
  • Fill the container with Argon
  • Fill the container with Sulfur HexaFluoride (HF6)
  • Super cleanliness of insulator around the electrical contact to the outside world
  • Hydrophobic coating on that insulator
  • Of course no sharp edges or points on external connection, a sphere is best
  • Enclose the whole thing in another vacuum chamber or in a dry Nitrogen atmosphere
  • If the whole thing is not in a vacuum, then shield from ionizing radiation, including UV light
The above is just "stream-of-consciousness", and some or all may be no good at all!:wink:
18K
