Electrostatics from particle laden air
4 replies · 1K views
Niki
Is it possible to generate static electricity from air flow containing particles example smoke or dust flow, or does anyone know of experiments such as the kelvin water dropper converted to generate static from air flow ?
Thanks
It very possible. Grain transporters and silos use air to move grain around. Unfortunately the mixture of dust and air can be explosive and generate sufficient static electricity to trigger an explosion.
Warning - speculation !
I've often wondered if something like this could be used in a Van de Graaff arrangement. But I'd assumed I could just rely on ionising air molecules.
If you used dust, I wonder how you would discharge the particles? When they passed through the mesh / past the brushes, wouldn't they be attracted and tend to stick? Perhaps tiny metallic particles would work better, as they would discharge on contact.
The problem with both VdG and Kelvin generator might be the repulsion as the charge builds up, but with solid particles if you drive them fast enough I suppose you can overcome that (the water drops disintegrate.).
Perhaps also worth looking at how the charge needed to create a lightning strike is built up.
Merlin3189 said:
…Perhaps tiny metallic particles would work better, as they would discharge on contact …
DON’T DO IT! I used to work in a robotic welding factory. The air was always a bit hazy, and most of that haze was tiny metallic particulates. I can tell you from experience that they cling to everything. As a maintenance team, it was one of our biggest problems.
Sorry to be so emphatic, but I think I just had a little ptsd flashback.
