Rick16
- 213
- 71
Thread moved from the technical forums to the schoolwork forums
TL;DR: Griffiths, problem 2.46
Here is the problem statement:
The electric potential of some configuration is given by the expression ##V(r) = A \frac {e^{-\lambda r}} {r}##, where A and lambda are constants. Find the electric field E(r), the charge density ##\rho(r)##, and the total charge Q.
I have Griffiths' solution here. For the electric field he finds ##E=Ae^{-\lambda r}(1+\lambda r)\frac {\hat r}{r^2}##. When he then takes the divergence to find rho, the expression for the divergence includes the term ##\nabla\cdot (\frac {\hat r}{r^2})##, which, according to an earlier result in the text equals ##4\pi\delta^3(r)##, and his complete result for rho is then ##\rho = \epsilon_0 A[4\pi\delta^3(r)-\frac {\lambda^2}{r}e^{-\lambda r}]##. Next he finds that ##Q=0##.
Before looking at the solution, I tried to solve this problem on my own. I got the same electric field, except that I wrote it as ##E=A(\frac {\lambda e^{-\lambda r}}{r}+\frac {e^{-\lambda r}}{r^2})\hat r##. Taking the divergence I get ##\rho = -\epsilon_0 A \frac {\lambda^2}{r} e^{-\lambda r}##, the same result as Griffiths', except without the delta term. Given this rho, Q is not equal to zero.
I looks like the divergence depends on how I write the electric field, but that does not make sense. Algebraically, my electric field and Griffiths' electric field are equal, and from a purely vector calculus point of view I cannot see anything wrong with my divergence either. Where is the my mistake?
