Elementary holicopter question
  • Context: High School
  • Thread starter Thread starter zyenge
    Elementary
6 replies · 2K views
zyenge
If there's no tail rotor, Will the body of helicopter naturally turn along with the main rotor (in the same direction) or spin toward the opposite direction. Thanks! $15 bet with my friend ><
What do you think will happen and why? We have no way to know if this is a homework problem or not. The answer is pretty easy to figure out, and even to demonstrate (without a helicopter).
My friend think that----
the engine will turn the helicopter blade in one direction and the body of the helicopter in the opposite direction. The body will not rotate until it has left the ground, because it has friction with the floor. Also the body will spin with a rotational speed proportional to the mass of the body to the blades.I think if there's no engine which is no energy input, he may be right. But with continuing energy input, it's not a closed balanced system, energy makes blade spin, then while blade is spinning, the body of helicopter should rotate along with the rotor (same direction).
Sorry buddy. Ask your friend if he has a preference of bill denominations that he'd like his reward in.:-p
Agreed.
I'll elaborate.
The engine's torque drives the propellor and the fuselage in opposite directions; the engine does not care which end is the fuselage and which end is the rotor, its purpose is only to rotate its axle relative to its body.
Try firing up a power drill when its bit is embedded in something. Instead of the drill bit turning clockwise, the whole drill turns counterclockwise, and might twist your arm off.
In the same direction of course because of friction dragging the heilo body along. I think:confused:
