Elevator Frame Design: Can It Stand Alone?
The discussion centers on the feasibility of constructing an elevator frame and rails without utilizing rail brackets, relying solely on four steel columns for support. Participants emphasize the importance of adhering to elevator safety codes and the engineering principles involved in such designs. The consensus is that the proposed method is unsafe and not compliant with established regulations. The thread was ultimately closed due to the lack of understanding of these critical engineering standards.
  • Understanding of elevator safety codes
  • Basic knowledge of structural engineering principles
  • Familiarity with elevator design standards
  • Knowledge of load-bearing structures
  • Research elevator safety codes and regulations
  • Study structural engineering principles related to load-bearing designs
  • Explore standard elevator design practices and components
  • Learn about the role of rail brackets in elevator systems
Engineers, architects, and construction professionals involved in elevator design and safety compliance will benefit from this discussion.
EnricoHendro
TL;DR
I am wondering if it is possible to build an elevator frame without using rail brackets
Hello there,
I am wondering, if I were to build an elevator in a building, is it possible if I build the elevator frame (and rails) without using the rail bracket? The weight of the cart plus the contents would be supported by only 4 steel columns fixed to the ground. I know it is a silly question, but I am just curious.
No, because your question shows that you do not understand the engineering involved. Nor do you understand elevator safety codes, or the reason for those codes. Please read the rules - PF is not a consulting engineering organization.
Thread closed.
  • · Replies 18 ·
  • · Replies 22 ·
