Understanding EM Fields: Storage and Transmission of Energy
  • Thread starter Thread starter spaghetti3451
    Em Energy Fields
Electromagnetic (EM) fields indeed contain energy and can store it, as seen in capacitors, while also transmitting energy through waves. The distinction between storing and containing energy lies in the context of usage; storing refers to the ability to hold energy for later use, while containing refers to the presence of energy within the field itself. The definition provided describes an EM field as a configuration of electric fields that can be static or dynamic, which aligns with established principles. Additionally, a changing EM field induces a magnetic field, consistent with Maxwell's equations. This understanding is crucial for grasping the fundamental behaviors of EM fields in various applications.
spaghetti3451
I have been told that
1. EM fields contain energy.
2. EM fields can store energy, e.g. capacitors.
3. EM fields can transmit energy, e.g. via waves.
How are 1. and 2. any different from each other?
The two statements say the same thing using different words.
Thank you very much for your reply.
To move on, I just want your view on this definition of mine.
An electromagnetic field is an arbitrary configuration of electric fields (either finite or infinite in extent) that is either static or changing in time.
If the electromagnetic field changes in time, a magnetic field is induced whose properties and configurations are given by Maxwell's equations of electromgnetism.
Am I right?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
