Understanding the Time Offset in EM Plane Waves
  • Thread starter Thread starter maxsthekat
    Em Plane Wave
The discussion centers on the mathematical representation of electromagnetic (EM) waves, specifically the equations for the electric field E(x, y, z, t) = E0sin(kx - wt)y_hat and the magnetic field B(x, y, z, t) = B0sin(kx - wt)z_hat. The minus sign in front of the wt term indicates that the wave propagates in the positive x direction, while a positive wt would imply propagation in the negative x direction. This relationship is clarified through the concept of wave shifting, where the function f(x-1) represents a shift in the wave's position along the x-axis.
  • Understanding of electromagnetic wave equations
  • Familiarity with sinusoidal functions
  • Knowledge of wave propagation direction
  • Basic calculus concepts related to function shifting
  • Study the derivation of electromagnetic wave equations
  • Learn about wave function transformations and shifts
  • Explore the implications of wave direction on signal processing
  • Investigate the properties of sinusoidal functions in physics
Students of physics, educators teaching electromagnetism, and professionals in fields related to wave mechanics and signal processing will benefit from this discussion.
maxsthekat
This isn't a homework question so much as a general question about the equation I see used in the textbook:
The E field of an EM wave is defined as E(x, y, z, t) = E0sin(kx - wt)y_hat and the B field of an EM wave is defined as B(x, y, z, t) = B0sin(kx - wt)z_hat.
Why is there a minus sign in front of the wt term? I understand how kx (the offset in space) is positive; why wouldn't the time offset (wt) also be positive in this equation?
Thanks!
-Max
The minus sign just means the wave is traveling in the +x direction.
You could have it be +wt. In that case the wave travels in the -x direction.
I see... But, why is a +x direction a -wt term?
At t = 0
. f(k). .........
At t = t
..... f(k-wt) .....
Where f(k) is a pulse
see f(x-5) goes towards positive side and f (x+5) is at negative side or you can use the word "shift". This can understood good if you use one simple pulse rather than a complex sinusoidal function
Hmmm. Well, let me ask a somewhat more basic question. Do you understand why a graph of the function f(x-1) would look the same as f(x), except that it would be shifted by 1 unit in the +x direction?
  • · Replies 21 ·
