Understanding EM Spectrum: Emitting vs. Reflecting | IR Camera Examples
This discussion focuses on the distinction between emitting and reflecting infrared radiation in the electromagnetic spectrum, specifically using mid-infrared (IR) cameras. The example provided illustrates how water, which absorbs IR at 7 microns, emits radiation after absorbing it, while polished steel reflects IR due to its high reflectivity. Key terms such as "specular reflection" and "diffuse reflection" are defined, highlighting that specular reflection occurs on smooth surfaces and diffuse reflection on rough surfaces. The conversation concludes that while both emission and reflection can appear similar in camera signals, they differ in terms of temperature and wavelength characteristics.
  • Understanding of electromagnetic spectrum concepts
  • Familiarity with mid-infrared (IR) cameras
  • Knowledge of reflection types: specular and diffuse
  • Basic principles of thermal emission and absorption
  • Research "mid-infrared camera specifications and applications"
  • Study "thermal emission principles in materials science"
  • Learn about "spectral analysis of reflective surfaces"
  • Explore "temperature effects on infrared radiation detection"
This discussion is beneficial for optical engineers, materials scientists, and anyone involved in thermal imaging or infrared spectroscopy applications.
AkshayPitt
Hello,
I was wondering how one would be able to tell the difference between an object emitting a certain wavelength of the EM spectrum, vs. an object reflecting that same wavelength of the EM spectrum. For example:
1) Suppose I have an IR source at 7 microns. I point this source at water, and capture data via a mid IR camera. Water has great absorption at 7 microns, so I don't see a direct reflection of the source captured by the camera. However, I do see that the water is emitting IR at 7 microns after having absorbed most of this radiation from this source.
2) I point the same source at a sheet of polished steel. I capture the data via a mid IR camera again. Polished steel has very high reflectivity, so I see almost a direct reflection of the source captured by the camera.
Would the signal captured by the mid IR camera look different in the two cases above?
Thanks.
Science news on Phys.org
AkshayPitt said:
polished steel. I
"Specular reflection." You'll also want to look up "diffuse reflection" and "cosine scattering."
Thanks a lot for your response. After looking up those terms, I understand that specular reflection happens on smooth surfaces, and diffuse reflection happens on rough surfaces. What I am still confused about, however, is the difference (from the perspective of a camera) between emission and reflection. I'm not sure if I'm missing something, but to me it seems like the camera would see emission and reflection the same way.
Rather than taking the example of water and polished steel, let's say there are two pieces of polished steel. Assume one piece of steel was already hot before coming into the camera's vision - the camera would pick up the emission of infrared from this piece of steel. Imagine that the second piece of steel has infrared reflecting off of it - the camera would pick up the reflection of infrared off of this piece of steel. Would these two camera signals not look very similar?
In the case of a specular surface, reflected radiation will give you an image of the original source. and the radiation emitted by the reflecting surface can give you only an image of the emitting surface itself. There will be additional differences in wavelengths of maximum intensities if there are temperature differences between the surface and the source being reflected.
  • · Replies 152 ·
11K
  • · Replies 23 ·
23K
16K
