Energy and power supplied by a bicyclist
The problem involves calculating the energy supplied and average power output of a bicyclist based on the torque generated during pedaling. The context includes the relationship between torque, angular speed, and work done in a rotational motion scenario.
  • Participants discuss the application of the work-energy theorem and the need for calculus due to the time-dependent nature of torque. There are attempts to set up integrals to calculate work done over a complete cycle and questions about the limits of integration.
Several participants have provided insights into the integration process and the correct evaluation of limits. There is ongoing clarification regarding the interpretation of torque over the pedaling cycle and the correct application of formulas for energy and power.
Participants note the importance of considering the half-cycle of pedaling and the implications of torque being negative in certain intervals. There is also mention of potential errors in evaluating expressions and the need for careful consideration of units in calculations.
welssen
In bicycling, each foot pushes on the pedal for half a rotation of the pedal shaft; that foot then rests and the other foot takes over. During each half-cycle, the torque resulting from the force of the active foot is given approximately by τ = τ0 sin ωt, where τ0 is the maximum torque and ω is the angular speed of the pedal shaft (in s-1 as usual). A particular cyclist is turning the pedal shaft at ω=70.0 rpm, and at the same time τ0 is measured at 38.5 N•m.
Find:
(a) the energy supplied by the cyclist in one turn of the pedal shaft and
(b) the cyclist's average power output.
Work:
W = τθ, with θ the angular displacement;
Work-energy theorem:
W= ΔKE = Energy supplied by the cyclist
For (a) I thought of using the work-energy theorem the following way:
E=τ0 sin(ωt)θ
with:
- θ=2π rad=one revolution
- t=θ/ω
So I get E = 38.5*sin(ω*2π/ω)*2π = 0 !
This is not really what I expect...
For (b) there may be a rotational version of P=F*v that is P=τω.
Thanks for your help
Welcome to PF!
E=τ0 sin(ωt)θ
Since the torque depends on time, you will need to use calculus.
Yes, but this would give the instantaneous power. You want the average power.
Thank you!
So I apply the following integral from 0 to 2π:
W=∫τ0 sin(ωt)dθ
Then :
dθ/2π = dt/T (T:=total time=2π/ω) ⇒ dθ=ω dt
⇒ W = ∫τ0 sin(ωt)/ω dt = -τ0 cos(ωt)/(ω^2)
Evaluating the integral from 0 to 2π gives 0, again. Or should I integrate from 0 to π for the up-down movement?
Thanks again for your answer
welssen said:
So I apply the following integral from 0 to :
W=∫τ0 sin(ωt)dθ
Note that the expression τ0 sin(ωt) only holds for half a cycle. (This expression would give a negative torque for the second half of the cycle. But this doesn't happen. Instead, the other foot takes over.)
Then :
How did ω get into the denominator?
Yes, integrate θ from 0 to π; or integrate t from 0 to the time corresponding to θ = π.
Very nice, thanks!
This was a mistake indeed, it's supposed to be in the nominator.
So just a recap for (a):
W = ∫τ0 sin(ωt)dθ = -τ0 cos(ωt) → from 0 to π gives → Supplied Energy = W = τ0 cos(ωt)
We must consider that ω in the cos term has unit s^(-1) so we multiply it by 2π to have it in rad/s.
Numerically,
ω=70 rpm = 7.33 rad/s
t=π/ω=0.429 s
So E = 38.5*cos(2π 7.33⋅0.429) = 23.68 J.
So the energy supplied for one turn is:
E = 47.36 J.
(b) The average power is the work difference per unit time which leaves:
P = ΔW/(2*Δt) = 47.36/(2*0.429) = 55.20 W.
(And here Δt is multiplied by 2 for both feet movements)
Hopefully this is correct.
OK
I don't think you evaluated at the limits correctly. Otherwise, your work for the rest of parts (a) and (b) looks correct to me regarding method.
Just caught something else.
t=π/ω=0.429 s
So E = 38.5*cos( 7.33⋅0.429) = 23.68 J.
Why the factor of 2π? Note that t=π/ω tells you that ωt = π. That's all you need to evaluate cos(ωt).
Thanks.
Oh I see... I thought that, as ω is specified to be given in s^(-1), we were expected to convert it into rad/s (so multiplying it by 2π)... But OK I understand it now.
So actually
(a) E = 2*38.5 = 77 J.
(b) P = 89.7 W.
welssen said:
So actually
(b) P = 89.7 W.
I think these answers are off by a simple factor due to the fact that you didn't evaluate W = ∫τ0 sin(ωt)dθ = -τ0 cos(ωt) correctly at the lower limit (t = 0).
  • · Replies 20 ·
