adi said:
An elementary electron-> electron + gamma process can not occur by itself in the vacuum because if we assume the photon invariant mass zero and the electron invariant mass positive, energy and momentum can not be conserved at the same time. The delta E may be computed and from the energy time incertinty principle we compute delta t, the maxium time allowed for the energy violation. After this time interval, whether the electron or the photon must interact further in order to have a process allowed in the vaccum.
If on the other hand we assume the momentum and the energy conservation simultaneously, the electron invariant mass positive and the photon invariant mass unknown, we compute the latter and find it pure imaginary. What would be the physical sense to this.
So, is energy conserved in elementary vertices or not?
Adrian Buzatu
Okay,Adi,here's my view:
I guess you're having in mind the elementary process of QED,the vertex with 2 fermionic lines and one photonic one.Let's separate this vertex from the scattering process itself (a priori described by a very comlicated F diagram)and discuss it and only it.
Let's assume we have a photon which is emitted by an incoming electron.I state that this process is not a physical one,unless,one of the three (actually 2,but there are 3 propagators in all) particles is not physical,else it is VIRTUAL.
PROOF:1.Because it is an elementary process,we can assume that the total 4momentum is conserved.If we assume that and the fact that ALL THE PARTICLES ARE REAL,MEANING THEY ARE ON THEIR MASS SHEET,we have a contradition.4-momentum is not conserved.
2.Conserving of 4-momentum implies that one of the particles (let's pick the photon,like in a Bhabha or Moeller scattering) is virtual,which means IT IS NOT ON ITS MASS SHEET.
In the case of the photon,u get indeed negative eigenvalue for \hat{P}^{2},which would mean a tachyonic state...
ENDPROOF.
Therefore,u can chose:either consider the three particles as being real,on their mass sheet,and then energy momentum will not be conserved in vertex,or take energy-mementum to be conserved and end-up with one virtual particle.
MY ADVICE IS TO TAKE THE SECOND ALTERNATIVE.
Take the Bhabha diagram of scattering.The incoming particles are real and the photon they change is taken as virtual/nonphysical.The trick is that taking the photon as nonphysical will not alter your results,as in the S matrix element between the 2 states (final and initial) no element from the description of the photon (neither spin,nor helicity,nor momentum,nor energy) interviens.U can check that one...
Take 4momentum to be always conserved in fundamental vertices in QFT.It's only way you can know which particles are real (on their mass sheet) and which are not (are virtual/are not on their mass sheet).
This vertex is the typical example when speaking about virtual particles.
Daniel.
