Energy density due to infinite uniform line charges
The discussion revolves around calculating the energy density due to infinite uniform line charges, specifically focusing on the interaction between two rods in the x-y plane and their contributions to the electric field and potential energy. Participants are exploring the implications of their equations and the physical interpretations of energy density in this context.
  • Participants discuss the validity of equations related to electric fields and energy density, questioning assumptions about boundary conditions and the nature of infinite charge distributions. There are attempts to relate potential energy to energy density and to clarify the implications of moving rods on the electric field.
The discussion is ongoing, with participants providing insights and raising questions about the correct interpretation of energy density and the equations involved. Some participants suggest that the energy density should be understood in terms of integrals over specific regions, while others express confusion regarding the relationship between potential and energy density.
There is a mention of constraints related to the static versus dynamic nature of the rods, and the need to consider the implications of moving charges on the electric field. Participants are also navigating the complexities of interpreting energy density in relation to the geometry of the problem.
  • #31
PeroK said:
Yes, it's tricky. One idea is to go back to your original idea of using the electric field!
Those integrals were infinite too :(
  • #32
Where did you get this problem?
  • #33
It was simply suggested in class I have literally 0 reference on it. And the energy density was defined as the energy in the field between the plane z=a and z=a+1. But I cannot find a way to calculate that that doesn't end up being infinite.
  • #34
You've been quoting a finite answer, though. Where did that come?
Karl86 said:
whereas the expression I need is something like ##C \cdot \log (|r_2-r_1|)##.
It's possible that the question is ill-defined. You've got two "infinite" wires and they start "infinitely" far apart.
You could interpret that different ways. Do they start "far apart" compared to their length? Or, are they "long" compared to the distance they start apart.
The answer you quote, if you take ##C##, just to be some constant of proportionality can be naively obtained from the the potential formula (*). But, that presupposes the problem has a unique, well-defined numerical answer.
(*) I hadn't thought any further than that until you forced me to think about it more clearly.
I suspect if you put different proportions into the ratio of lengths of wires and starting distances you would get different answers, potentially infinite if you take the limit in all cases.
For any finite problem (long wires, far apart), there will be a value of ##C## and an equation related to the log of the final distance apart. Approximately.
  • #35
The answer is given: it is ##-\frac{2\lambda^2}{4\pi\epsilon_0} \log(|r_2-r_1|)##. What I am asked is to prove that it can be written like that. How is it you got that expression naively? If I get right the ##\log(|r_2-r_1|)## bit I am basically done.
  • #36
You start with one "infinite" wire. You bring a unit of line charge in from "infinity" - and don't worry that the potential is infinite at infinity - and you have the energy to create the configuration, per unit length of the second wire.
But, now it seems very clear, if you released that unit line charge, it has infinite potential energy. So, there is no finite answer.
If, however, you consider the wire long but finite, then eventually the logarithmic potential will cease to hold. The PE of the unit length of charge is, therefore, finite for any finite wire, but tends to infinity for an infinite wire, so the problem is not well-defined.
  • #37
You are seeing it in terms of energy to get a certain configuration, but the wires are fixed in a constant position. There are no assumptions on how close or far they are, not infinitely far though, one intersects the xy plane in a point r_1 and the other in a point r_2. What the question seems to point to is they generate a field and this field carries some energy. Calculate it between the planes z=a and z=a+1. Is the way you are trying to see it equivalent to this?
  • #38
Nevertheless, they store infinite energy per unit length.
The analysis I did is necessary to calulate the energy stored, either explicitly or through a previously derived formulas, that uses the "bring a charge in from infinity" approach. Note also:
PeroK said:
To get that equation - the integral of ##E^2## - you need to neglect a boundary surface integral, which is not valid if the charge distribution is not bounded.
Do you know another equation for electrostatic energy ?
I overlooked that the same objection applies to the other formula using the potential.
In short, you cannot define the energy stored in the field of an infinite wire, because the potential is not finite at infinity.
The moral is that you need to be careful with these hypothetical charge distributions that go to infinity.
  • #39
Ok so you stand by your analysis that it seems not well defined, but what did you mean when you said that ##C\log(|r_2-r_1|)## can be deduced from the configuration? How?
  • #40
What happens if you release a positive point charge in the field of an infinite positively charged wire?
What is the final KE of the charge?
  • #41
The field is constant and pushes it away from the wire, the charge never stops, so the KE is never 0. IS that right?
  • #42
It's not a question of whether it stops or even whether the force is never zero - those apply to a point charge source as well - the issue is that the force drops off as ##1/r## and the potential is logarithmic, so that there is no final asymptotic KE "at infinity". The KE increases without bound.
Therefore, the PE of the point charge is not well defined.
The infinite wire configuration, although useful for calculating the potential difference between two finite points, as an approximation of a long finite wire, is ultimately a purely hypothetical configuration, with infinite energy density.
  • #43
Yes, I'm convinced. The discussion that arose from a seemingly innocent problem was remarkable though :D
  • #44
PS The only question now is whether this question was a deliberate "sandbag" or a genuine misconception on the part of whoever gave it to you!
  • #45
It was not a deliberate sandbag, it is meant to be answered correctly, so as things stand I am failing to answer it properly, and yet I communicated it to you correctly, and I am persuaded the discussion is correct.
  • #46
Oh, ok I asked my instructor and I was told to set the reference point not at infinity but at a finite distance from the wire. Do you think that can help?
  • · Replies 18 ·
  • · Replies 23 ·
