Energy dissipated in a resistor
Bob jefferson
A resistor of resistance 10Kohms has voltage across it described by the function
V(t) = 6sin(10t+pi/4)*exp(-2t) Volts
Calculate the energy dissipated in the resistor between t=0 and t=0.5
I have done the definite integral and have got 0.324 but i am not too sure if i am supposed use this answer in P=V^2/R .
on Phys.org
Definite integral sounds good, the question is which integral exactly?
Also, the units of the answer should be supplied.
I integrated this V(t) = 6sin(10t+pi/4)*exp(-2t)
Does the integral ##\int V(t) dt ## have the dimension of an energy?
No
I think the answer should be in joules as its asking for energy dissipated.
That's correct. As DrDu pointed out, the integral you did doesn't have these units. Why did you go away from P = V^2 * R? What are the units of power? How do you go from power to energy?
Hint: Energy is the time integral of power.
so i just multiply 0.5s with the value i obtained from the integration.
No, you need to perform another integration where what you are integrating is the instantaneous power.
Oh so actually putting V^2/r in the integral.
Yes. Try this and tell us what you get.
so would it be some thing like ##\frac 1 R \int_0^{0.5} V^2(t) dt ##
Yes.
phyzguy said:
Yes.
so i need a bit of guidance, would ##sin^2(10t+\frac \pi 4)## equal to ##\frac 1 2(1-cos(2*10t+\frac \pi 4))##
[itex]\sin^2(x) = \frac{1}{2}(1-\cos(2x))[/itex], but that's not exactly what you wrote. The 2 should multiply everything inside the cos argument.
13K
